I have several files I am attempting to convert to H.264 and I am having problems. The files are either DivX or XviD and I have tried using both mencoder and x264.
Mencoder creates a file for me that cannot be played on any player. FFMpegX indicates that the file has a duration of 0:00:00.
x264 creates a file that can be played, albeit incorrectly. The video is compressed to ~25 minutes and played at high speed with no audio. Afer the completion of the video the audio plays at normal speed with a blank screen.
The videos I am converting are high resolution, high bitrate video files. My attempt to convert simply to MP4 resulted in some choppiness in the video.
H.264 is the only acceptable video format I can use... please help.
Thread: Failed conversion to H.264
Higher than 960x544, 1850 kbps, 700 MB per 44 mins?Originally Posted by camevad
Please post output file size and the log (Process Information)Originally Posted by camevad
Try Decoding with QuickTime, if you can get QuickTime player to play your source file correctly; having installed the right QT codecs (DivX, AC3).Originally Posted by camevad
1290x720 4Gb/120m so it's bigOriginally Posted by Case
I don't have the log, but I do have all of the quicktie components installed and still nothing will play on any player.
I do not have such large XviD files, so I can't test with it.Originally Posted by camevad
Then we can't find any errors to fix in there.Originally Posted by camevad
Your source file won't play, or your output file won't play? What I was trying to say is, if QuickTime Player can succesfully play your source file, then ffmpegX can (if selected) use QuickTime architecture to read your source file, instead of using ffmpeg, so to utilize QuickTime's timing for better syncing video and audio. That's the beauty of having multiple decoders available within one tool; sometimes the other decoder brings better results.Originally Posted by camevad
I'm having the same problem and i cannot use another decoder cause only mencoder supports subtitles
I'm having the exact same problem.
Here's the log:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Sun Feb 4 02:56:15 CST 2007
Mac OSX universal build for ffmpegX
configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
Input #0, avi, from 'an.avi':
Duration: 00:04:25.8, start: 0.000000, bitrate: 6298 kb/s
Stream #0.0, 29.97 fps(r): Video: mpeg4, yuv420p, 1280x720
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 320 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, 29.97 fps(c): Video: rawvideo, yuv420p, 1280x720, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
[mpeg4 @ 0x54340c]frame skip 8
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
mp4 [info]: initial delay 1001 (scale 30000)
error, non monotone timestamps 9009 >= 9009
(Pages and pages of this here)
error, non monotone timestamps 23918895 >= 23915892
video:0kB audio:0kB global headers:0kB muxing overhead inf%
x264 [info]: slice I:35 Avg QP:27.97 size: 29672 PSNR Mean Y:42.46 U:48.52 V:48.48 Avg:43.66 Global:42.94
x264 [info]: slice P:3127 Avg QP:31.20 size: 14496 PSNR Mean Y:39.25 U:46.62 V:46.53 Avg:40.59 Global:39.89
x264 [info]: slice B:653 Avg QP:32.88 size: 7915 PSNR Mean Y:37.99 U:45.95 V:45.97 Avg:39.38 Global:38.75
x264 [info]: mb I I16..4: 59.3% 0.0% 40.7%
x264 [info]: mb P I16..4: 23.6% 0.0% 14.1% P16..4: 27.8% 0.0% 0.0% 0.0% 0.0% skip:34.6%
x264 [info]: mb B I16..4: 8.4% 0.0% 5.1% B16..8: 22.0% 0.0% 0.0% direct: 3.4% skip:61.1%
x264 [info]: PSNR Mean Y:39.063 U:46.519 V:46.451 Avg:40.407 Global:39.692 kb/s:3238.93
encoded 3815 frames, 9.11 fps, 3240.28 kb/s
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'an.mp4':
Duration: 00:02:07.2, start: 0.000000, bitrate: 3242 kb/s
Stream #0.0(und), 29.97 fps(r): Video: h264, yuv420p, 1280x720
Input #1, avi, from '/an.avi':
Stream #1.0, 29.97 fps(r): Video: mpeg4, yuv420p, 1280x720
Stream #1.1: Audio: mp3, 48000 Hz, stereo, 320 kb/s
Output #0, mp4, to 'an.mp4':
Stream #0.0: Audio: aac, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #1.1 -> #0.0 [sync #0.0]
[NULL @ 0x54340c]frame skip 8
video:0kB audio:4083kB global headers:0kB muxing overhead 2.398729%
IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels)
Saving an.mp4: 0.500 secs Interleaving
Encoding completed on Sun Feb 4 03:12:14 CST 2007
Lossless Conversion from AVI H.264 to MP4 H.264
By kenchen in forum Video ConversionReplies: 3Last Post: 22nd Oct 2010, 14:04 -
.264 Conversion
By thunderclap82 in forum Video ConversionReplies: 4Last Post: 11th Mar 2010, 17:48 -
Looking for H.264 conversion help
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 24th Nov 2009, 05:19 -
H 264 conversion
By Russo in forum Video ConversionReplies: 95Last Post: 8th Oct 2009, 16:38 -
H.264 (MOV) to H.264 MPEG TS conversion
By svens in forum Video ConversionReplies: 0Last Post: 19th Feb 2009, 06:47
