  1. Member coody's Avatar
    Jan 2005
    I got a new DVD RW drive and installed it. After first time I opened it, I was prompted I can change the region code 5 times, from region 1 to 6. The region 1 is by default. After I selected it, the region code setting message has not showed up again. Why did the DVD drive show the region code after the installation? I thought the region code is related with the DVD movie disc only. If the DVD drive can be selected the different region code, is it possible to disable it so the drive can play and record any region code DVD disc? Can someone explain it?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    There are several ways of getting around the problem. A firmware update for the drive might get you region free but such firmware is usually never from the factory....it is third party firmware.
    There is also the software route....stuff like AnyDVD can help too.
    I use neither. I have two burners....one set to region 1....one set to region 2(which usually always includes 4)...that's all I need.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    As has been pointed out, there are firmware updates that will probably remove the region restriction and any riplocks on your drive, however using these will void your warranty if they are not from the manufacturer (and they won't be).
    AnyDVD is pretty good, but costs. DVD43 is also pretty good, and free. Might be worth a try in the short term.
    Read my blog here.
  4. A lot of models have "hacked" firmware available, that is, firmware that has had regions codes removed by a third party. This will not be supported by the manufacturer, so if something goes wrong, you will be on your own...
  5. Member daamon's Avatar
    Melbourne, Oz
    The software option is, for the reasons already stated above, my preferred option. I use Region Free DVD from www.dvdidle.com - there's a full and lite version.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
