Hi everyone, Im having a little trouble with dvds thats im burning. The problem is after i convert my avi files to dvd format, then burn them to disc I am always missing over half of the video. Everything converts fine and burns right. I am using allok AVI to dvd and nero. why is this happening to me to everything i burn that is pirated??? and yes i am adding all of the dvd files..someone please help me. THX.
Thread: Missing footage
If you are asking about converting downloaded copyrighted movies, that would be in violation of our rules and will get you a warning card.why is this happening to me to everything i burn that is pirated???
Please read our rules before posting. Moderator redwudz
If they are not copyrighted and are converted properly and burn properly, try different DVD media. That's the most common problem with DVDs not playing correctly. If that fails, try a different converter and burning program. ConvertXToDVD works well.
oops.. sorry
no it doesnt work.
Get a DivX/XviD capable player. Can be had for about the same money as most commercial AVI to DVD offerings. No need for any conversions any more.
/Mats
I should have mentioned, I dont like watching movies on a computer...the orginal avi files play fine on the comp, its only when I convert them to dvd files i have the problems of missing footage and there is more than enough space on the disc.
I should have mentioned, I dont like watching movies on a computer...the orginal avi files play fine on the comp, its only when I convert them to dvd files i have the problem of missing footage and there is more than enough space on the disc.
Again:
By "player" I mean a "standalone DVD player".Get a DivX/XviD capable player
That an AVI plays fine on your computer is no indication of if it's error free, and suitable for conversion, as players can gloss over many problem spots, while an encoder expects each and every source frame to be decodable.
/Mats
Improving Old Footage?
By PHNeedsHelp in forum EditingReplies: 1Last Post: 1st Jan 2012, 10:50 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 14:24 -
MPEG Output file missing video footage
By bz186 in forum SVCD2DVD & VOB2MPGReplies: 15Last Post: 9th Sep 2009, 02:29 -
Noise on dv footage
By cd090580 in forum RestorationReplies: 3Last Post: 3rd Nov 2007, 19:08 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 04:54
