In a previous post in this forum, I talked about replacing my current monitor and then connecting my CPU VGA's output to a LCD HDTV VGA's input. The HDTV has a VGA input resolution of 1366X768 60hz requirement. My CPU's VGA output is 1360X768 60hz.
So while I was surfing the net to see what a 10' VGA to VGA cable would cost, one site said a VGA to VGA connected to a TV would only pass up to 640X480--that got my attention!
However, I want to connect to a HDTV VGA input that is compatable with my CPU's output (an ATI Radon X300 I think).
So would a 'standard' VGA to VGA cable work with these 15-pin connections and pass and receive the resolutions indicated? Or would I need to purchase something different like a SVGA or XSVGA cable? Thank you.
Yes at 10ft a normal VGA cable will work. 15ft or over should be "double shielded" and better quality.Originally Posted by usaf64
If you have a solid VGA card, then you most likely can drive 15ft of VGA signal. Better VGA cards use better analog video ampilfers which give sharp and strong drive.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Help with long VGA cable
By bud79 in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2010, 14:34 -
VGA to DVI-D cable
By ljCharlie in forum DVB / HDTVReplies: 22Last Post: 13th Jan 2010, 13:07 -
cable: vga to s-video
By themaster1 in forum ComputerReplies: 7Last Post: 16th May 2008, 17:25 -
VGA Cable Length?
By stim141 in forum DVB / HDTVReplies: 11Last Post: 19th May 2007, 03:59
Statistics
Newest guides
Latest tool updates
New media comments
