What is the best VCD/MP3 CD player out there? I been looking at the Supertek MP-2001V, the NAPA DAV311, the Supertek EN-2001V, and some others. Does anyone have any of these or any other portable VCD/MP3 cd players? please post any experience (and which one you have) here. Thx
Thread: Portable VCD/MP3 Players
I got the Napa Dav311 for christmas. Although it is quite a good little unit, I have to say that the VCD playback is a little hit or miss. Some will play back fine, with the occasional jump when a lot of stuff is happening on screen. Others, will be just unwatchable, like Kalifornia, where it pauses every couple of seconds.
MP3 playback on the 311 is pretty good, if you ignore the harmonic distortion it puts on the vocals of some songs.
In clonclusion, the 311 is a good device, but is probably not the best on the market.
Hope this helps.
I bought the supertek portable, and it works fine for mp3. VCD is OK-I use it in the car for trips, and it does well with some vcds, but others give lots of skips. Sometimes FF or RW stops it. It also appears to be disc dependent, as TDKs I use tend to skip more than a no name CDR. All in all, for $80 a decent deal.
I like it better than playing tapes-easier to carry and the player takes up minimal space in the car.
Portable DVD Players With USB Support
By JohnDodds in forum DVD & Blu-ray PlayersReplies: 4Last Post: 10th Jan 2010, 16:17 -
PORTABLE Dvd Players vs. ones with DivX
By maris in forum DVD & Blu-ray PlayersReplies: 12Last Post: 4th Jan 2010, 11:06 -
dvd players and portable hdd?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2009, 16:44 -
questions about portable dvd players ...
By oxstrawberrikiss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th Dec 2007, 21:04 -
multi-region portable dvd players
By mech1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 06:36
Statistics
Newest guides
Latest tool updates
New media comments
