VideoHelp.com Forum
Results 1 to 9 of 9
    hey Guys, i got a movie on my computer, but the audi is in AC3, wich means i can't hear they talk on my stereos. i want to convert the audio to 2 channels (i think) mp3. i did already with xilisoft video converter, but the movie that was 680 MB gets bigger, to almost 1GB, and the video is the saame quality, i only change the audsio to MP3. anuy easier way to edit the audio without messin with the video?
  2. Member mats.hogberg's Avatar
    Get the Lame dll for VirtualDub, load the avi, set video to direct stream, set audio to full processing, select and configure the mp3 codec, and save as a new AVI.
    /Mats
    ok, did all of that, but the videos comes out to be 1.1 GB and the source, is 680, shounldn't it be smaller than the source?
  4. Mod Neophyte Super Moderator redwudz's Avatar
    Did you set the video to Direct stream copy? If so the video size isn't changed.
    yes, no the video is the same, and the audio works as i wanted, i wento to audio, full processing mode, then, compression, Lame mp3. Thsn to video, and direct stream copy. The video and audio work great, but the file itself has doubleded the size, from 680 MB to 1.1 Gb i guess i'm still doing something wrong, cause should be smaller than it was before, shouldn't it?
  6. Mod Neophyte Super Moderator redwudz's Avatar
    It should not have gotten bigger. at least not doubled in size. Drop it into Gspot 2.60 and it should show the audio/video sizes.
    well i have no idea what that shows, but i'm putting the picture there... defnitally the audio is getting bigger, and i'm doing somehing wrong, but i don't know what yet....
  8. Your audio is being converted to PCM WAV audio, and not MP3 audio.
    ...but the audi is in AC3, wich means i can't hear they talk on my stereos.
    Why is that? Are you saying you can't hear the AC3 on the computer? Then install the AC3Filter, and quit trying to lower the quality of the audio.
    awesome manono awesome, works great, thank you =]]]
  1. Movie Audio to MP3 results in AVI File
    By valier_l in forum ffmpegX general discussion
    Last Post: 23rd Mar 2012, 12:27
  2. Replies: 1
    Last Post: 11th Oct 2010, 11:02
  3. Replies: 88
    Last Post: 14th Jun 2010, 04:04
  4. Replies: 6
    Last Post: 1st Oct 2009, 13:27
  5. MPEG2 Video with AC3 audio cannot convert to MP3 audio
    By wenglock in forum ffmpegX general discussion
    Last Post: 7th Sep 2009, 21:52
