I'm trying to convert my Xvid files to WMV so I can stream them via the Xbox 360 using Media Center. However, I'm not quite sure on what settings to use for a particular file.
It's an Xvid file at 960x528 resolution and 23.98 fps. My Xbox 360 and my TV are set up for 720p. Here are my questions for converting this file to WMV:
1) Should I keep the resolution the same? The 360 is able to play HD WMV files so I definitely don't want to downconvert. But should I upconvert to 720p or just leave it at 960x528?
2) Do I keep the frame rate the same or do I change it to something else like 29.97 fps or 24 fps?
I've already converted it once at 960x528 and 23.98 fps and it looks great other than a general stuttering during scenes with motion. I definitely used a high enough bitrate so that's not the problem, so I was wondering if it's because of the framerate or resolution? I have other WMV files at higher res 720p that do not do this.
Thanks.
I know this isn't going to help you out any, but I'm in the same boat kind of. What program you using?
I'm using Windows Media Encoder.
thanks, I'm tying to find a way to get my dvd VOB files into a wmv.
A general rule of thumb: If at all possible - keep the frame rate thruout the process. Changing frame rate is bound to cause A/V sync problems.Originally Posted by Jiggytrav
/Mats
Or use Transcode 360 or Tversity for realtime streaming from most video formats to the xbox360.
Right, I'm already using Tversity to stream to my 360 but my computer is not fast enough to transcode HD resolution files in real-time. So that's why I'm looking to convert them to WMV format first so that they don't need to be transcoded when streamed via Tversity.Originally Posted by Baldrick
Would one of the newer processors/computers be able to transcode a 720p file, for example, to WMV in real-time? I'm probably going to get a new PC soon anyway, but I wonder if even an X2 or Core Duo 2 would be able to do it on the fly? I have a P4 2.6 right now.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
question about converting wmv to avi (xvid) using Virtual Dubmod
By jimdagys in forum Video ConversionReplies: 5Last Post: 16th Apr 2008, 15:16 -
Converting WMV to divx/xvid
By mattr in forum MacReplies: 1Last Post: 3rd Jan 2008, 09:23
