Hi All,
Can someone tell me what VirtualDub and Avisynth filter will get ride of rainbow colors in the following frame? It comes up, in about 2 frames.
Thanks.
Matt
I keep forgetting this form coverts to all lowercase.
Matt
The following is the URL.
http://www.lwintegrationtest.com/badvideoframe.jpg
Hi-
Since you say there's only 2 frames of it, and since it looks to me like there's not a whole lot of movement in the frame, then perhaps the AviSynth FreezeFrame Filter will serve to replace the 2 funky frames with a good frame from before or after:
http://www.avisynth.org.ru/docs/english/
Perhaps better, but trickier to set up, will be to replace the colors of the 2 bad frames with good colors from a nearby good frame, using the Chroma Mode of the Overlay Filter:
http://www.avisynth.org.ru/docs/engl...rs/overlay.htm
For two frames I'd photoshop it, but freezing a frame here or there will be easier, if there is no movement in the frame.
remove chroma from a digital video and add new color to the luma
By rudolf016 in forum RestorationReplies: 3Last Post: 24th Feb 2012, 11:11 -
Any recommended settings for TMPGencXpress color filter?
By azmoth in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 11:29 -
remove region filter
By atomicock in forum EditingReplies: 5Last Post: 5th Nov 2009, 06:36 -
Can I remove color and letterbox MPEG2 video without losing quality?
By gamgamman in forum EditingReplies: 3Last Post: 10th Jul 2008, 22:22 -
Camcorder Color Denoise Filter for VirtualDub
By Soopafresh in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 17th Mar 2008, 13:30
