VideoHelp.com Forum
    i did a clean install for windows vista then i installed xp on another partition but when my computer boots up it wont let me go into windows vista it heads right to xp i downloaded a boot manager called OSL2000 it says it supports vista but vista wont show up on the boot screen anyone know how to fix this?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    I did a quick Google search for 'dual boot vista and XP' and got a few hits. Seems others are doing it with no major problems, though some of them are using the MS Beta version released a while back. One guide that might give you some hints from that search: http://www.lifehacker.com/software/t...sta-179906.php
    If not, take a look at some of the others.
    When you installed Windows XP it destroyed Vista boot loader. I'm afraid you'll need to reinstall/repair Vista.
    (I have Vista, XP and Linux on my computer ... but I installed Vista after XP, and then repaired grub with a live linux cd in order to be able to boot to linux)
    It's easier.
    Boot to the Vista DVD and choose Boot Options, then repair Vista boot. It may be called otherwise but those things are there.
    Then after a restart you'll find Vista's boot screen to boot to either Windows or Older Version of Windows. Windows is Vista, older version is XP's boot loader which will simply boot XP or provide its menu if you also have another version of Windows (like 9x) installed.
  1. MKV2VOB Problem in Windows Vista
    By aras298 in forum Video Conversion
    Last Post: 24th Mar 2010, 04:43
  2. Vista and Windows 7 both have problem with Indeo IV50
    By paj692 in forum Software Playing
    Last Post: 8th Jan 2010, 19:30
  3. Problem with Vobsub in Windows Vista 64 bits
    By Talayero in forum Subtitle
    Last Post: 30th Aug 2008, 10:23
  4. Windows Vista 64 bit, problem
    By reinnie in forum Capturing
    Last Post: 16th May 2008, 08:08
  5. Windows Vista Problem :(
    By 1magus in forum DVD Ripping
    Last Post: 24th Jul 2007, 22:08
