VideoHelp.com Forum
  1. I've used this program to make AVI
    FLV Extract
    Virtual Dub Mod
    VFW Plug-in from Cedocida
    DivX 6.x Codec
    And the question is,
    After i converted into DivX at 720x480 at birate 1500 kbps, still the final result is not very good. How i can convert to get high quality near DVD quality ??? and what plug-in i need for Virtual Dub Mod to get the best quality ??
    Thx
  2. VH Wanderer Ai Haibara's Avatar
    Most FLV movies you'll find on the net often use rather low resolution and bitrate, so they're often not going to look all that great converted to a higher-resolution AVI. Plus, they'll take another quality hit on re-encoding to that format.
    If you're going to author a DVD with it afterward, that's another re-encode.
    Unfortunately, you're probably not going to be able to get near-DVD quality from re-encoding FLV files.
  3. Originally Posted by Ai Haibara
    Most FLV movies you'll find on the net often use rather low resolution and bitrate, so they're often not going to look all that great converted to a higher-resolution video format. Plus, they'll take another quality hit on re-encoding to that format.
    So basically i need an DVD Author ?? to get the best quality ?
  4. VH Wanderer Ai Haibara's Avatar
    No. Depending upon what you're planning to do with the video, you want to avoid re-encoding it too many times... especially since the source is a low-resolution FLV video. Scaling it to a higher resolution and/or increasing the bitrate won't really increase the quality.
    There are post-processing filters for VirtualDub that you can use to attempt to improve the picture quality, but for a low-quality FLV video, it probably won't be of much help.
    If you are going to create a DVD from the videos, use a converter that will let you re-encode from the FLV video straight to DVD-spec MPEG-2 video.
  5. Member solarfox's Avatar
    Or, if that's not practical / possible, use a lossless (or nearly so) codec like HuffYUV to make your intermediate AVI file.
  6. Usually FLV files are of very low quality and small framesize. I have converted a few trying to imporve the quality and put them on a dvd for viewing on my TV.
    The filter list in VirtualDubMOD will probably be a little different for each file. That is going to depend on the quality of the original. If you take your time you can get some pretty good results although it won't be perfect. lol
    Here is a pretty good filter list to get you started. For filters you don't have just run a www.google.com search. They should be easy to find.
    Something that has worked for me is to resize to your 720 framesize but leave some black bars around the video (letterbox) so it does not show full screen on the tv set. Keeping it from blowing completely up to full screen will not show the flaws in the video so much. I have tried various amounts of black bars around the video but I guess that is a personal taste deal that you may not like. I don't mind some black bars if the video quality looks better. lol
    Can you post a link to the original ?
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. Replies: 2
    Last Post: 17th Sep 2011, 23:06
  2. Convert MKV to AVI/MPEG-2 High Quality file for HD author
    By ronorkis in forum Video Conversion
    Last Post: 1st Nov 2010, 08:23
  3. Replies: 0
    Last Post: 26th Oct 2009, 02:56
  4. AVI(w/ High Quality) to FLV issue
    By btmdan in forum Video Conversion
    Last Post: 8th Aug 2008, 10:35
  5. Replies: 3
    Last Post: 21st Jun 2008, 00:14
