VideoHelp.com Forum
    hi, im new to all this but I just downloaded a video it was a .bin file, I extracted it and it became 4 seperaye folders, which were EXT, MPEGAV, SEGMENT. and VCD, the files in the folders are either .vcd, or .dat Im just wondering how I can view this video?
    Don't extract the bin file, burn it as an image.
  3. What you downloaded is a complete CD image. You can burn it like that to CD. If you just want to view the files and your PC and not use a CD then use ISObuster and follow thi guide:
    http://forum.videohelp.com/viewtopic.php?t=141726
    You can also download and install Daemon Tools and it will let you mount the image as if it was on a disc. To your PC it will appear that a new (virtual) CD-ROM drive exists and your image will be there. You can load the *.DAT files in the MPEGAV folder into any software DVD player or Real Player, Windows Media Player, etc. and watch the VCD if you wish. stantheman1976's suggestion is certainly correct, but you may find it easier to just install Daemon Tools and use it to watch the VCD prior to burning. His method will take more time as you'll have to convert from DAT format to MPG, perhaps up to 10 minutes per DAT file.
  5. Member mats.hogberg's Avatar
    VCDGear can get the mpg out of a VCD image IIRC. But basiaclly, it's just a matter of burning the bin to a CD-R, provided you have the corresponding cue too, and pop it onto your DVD player.
    /Mats
  1. Help burning and playing VCD
    By NLO_Cliff in forum Authoring (VCD/SVCD)
    Last Post: 16th May 2011, 09:55
  2. VCD burning freeze
    By Douglas879 in forum Authoring (VCD/SVCD)
    Last Post: 28th Nov 2010, 15:23
  3. Burning .srt along with .avi onto a VCD
    By wox in forum Authoring (VCD/SVCD)
    Last Post: 5th Jul 2008, 08:35
  4. Help burning vcd
    By Reds in forum Authoring (VCD/SVCD)
    Last Post: 8th Feb 2008, 07:20
  5. vcd burning
    By srckaimal in forum Newbie / General discussions
    Last Post: 6th Dec 2007, 06:23
