VideoHelp.com Forum
    It was working fine yesterday but todat after opening the tray it wouldn't close. Does anyone might know what is wrong?
    Depending on unit .
    Tray's drive belt broken .
    Tray's drive gear malfuction (worn teeth)
    Tray's close / open sensor malfuction .
    Depend's if you pressed the button on the unit to close the tray or the remote .
    In case of remote ... batteries or defect keypad component .
  3. Make sure the tray can fully close, it may not even be apparent that it can't. I installed a brand new drive on my computer and switched the plate after which it wouldn't close. It was a very miniscule amount that wasn't allowing it to fully close, so little that it looked like it was fully closing...
  4. Make sure there isn't a dvd in the back somewhere.
    ALso try pushing it in with your finger.
  1. Panasonic S97 tray will not open
    By southland66 in forum DVD & Blu-ray Players
    Last Post: 8th Nov 2011, 01:24
  2. Panasonic AG-1970's front panel doesn't work
    By fravel in forum Restoration
    Last Post: 29th Dec 2009, 11:37
  3. Pioneer DVR-530 disc tray doesn't open
    By Alex_x in forum DVD & Blu-ray Recorders
    Last Post: 22nd Sep 2008, 16:39
  4. Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
    By daveshostack in forum DVD & Blu-ray Players
    Last Post: 12th Feb 2008, 11:41
  5. panasonic dmr-es46v doesn't work
    By Delreek in forum DVD & Blu-ray Recorders
    Last Post: 28th Sep 2007, 05:25
