VideoHelp.com Forum
  1. hi all. first off, i don't consider myself a newbie but i just wanted to post in the right forum.
    i have some downloaded AVI files that i want to convert to VCD. i have the DiVX codec installed and i can play the movies fine in Media Player but when i load them into TMPGEnc it says that it can't open the file or the file format is unsupported. i am using the latest version of TMPGEnc. i downloaded other clips from the same site and they worked fine.
    i renamed the files and some of the names are quite long would that make a difference?
    thanks for the help.
    -mark
    ps: i am running WinXP and i am using DiVX codec 3.11
  2. ...uuhmmmm....
    You could try to extract the audio 1st... maybe thats the error, if not.. reply, and i'll think of something else...
    or at least.... try to think of something else
    as long as my boss thinks i make a lot of money, i will pretend to work hard ;)
    Try to higher the priority of the direct show multimedia file reader.
    Options > enviromental settings > VFAPI plugin
    does the avi have VBR audio?
    if so that might be the problem.
    On Doom9 there a guide on that.
    _________________
    Ahh! Opposable digits!
    <font size=-1>[ This Message was edited by: agzz on 2002-01-17 13:29:36 ]</font>
  1. Replies: 8
    Last Post: 15th Apr 2012, 10:23
  2. Replies: 6
    Last Post: 20th Mar 2012, 10:22
  3. Replies: 6
    Last Post: 20th Oct 2009, 10:08
  4. Media Player Classic won't load ffdshow - choppy video
    By ioda006 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 6th Jun 2009, 21:44
  5. Media Player Classic can no play DivX files
    By siluet in forum Software Playing
    Last Post: 30th Sep 2008, 15:46
