This article by digitalFAQ at http://digitalfaq.com/media/dvdmedia.htm gives a table of quality rating of DVD media IDs and gives the manufacturer but not disk label names.
Just curious to know what label names are considered good quality for non critical data that you would prefer not to lose.
At computer swap meets in Australia budget DVD-Rs cost $16 to $20 for 50 wheras TDK and Sony are more expensive and Verbatim are the most expensive but are suggested for archiving important info.
What label names are good of the budget disks. You can't check the Media IDs until you get them home and even then some brands have multiple sources.
Are there any forums on this site that state DVD-R label name and likely Media ID and rated quality.
I used to get the "Record" brand of DVD-R from computer swap meetings, never had a bad burn with them yet.
On the cake stand of 50 they have written on them Azo dye & Pioneer certified.
I use a Pioneer burner, haven't purchased any for quite a while, still have 50 left.
Could also checkout DVD media under LISTS on the left.
Have a look at nomorecoasters.com.
good budget mobo to pair with amd fx-4100?
By Stealth3si in forum ComputerReplies: 8Last Post: 25th Feb 2012, 17:39 -
Good quality? What changes could be made?
By darkdream4 in forum DVD RippingReplies: 78Last Post: 11th Jan 2010, 21:35 -
Have I made the quality too Good?
By criddle in forum Video ConversionReplies: 1Last Post: 4th Apr 2009, 03:37 -
dvd +r made on lighton 5001 can't be read on desktop or lap top
By skydiverbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Jan 2008, 14:02 -
Good Starter Cam in a tight budget?
By acid_burn in forum Camcorders (DV/HDV/AVCHD)Replies: 12Last Post: 3rd Aug 2007, 23:48
Statistics
Newest guides
Latest tool updates
New media comments
