VideoHelp.com Forum
  1. Member ambrosechapel's Avatar
    I'm encoding AVIs for use on a Palm and the volume of the audio is just too low (I watch/listen on a train!) -- is there any way to increase the volume? There's an "audio gain" drop menu but it's greyed out. It's part of a "normalise audio" section, also greyed out.
    Input is mp3, 48000 Hz, stereo, 32 kb/s, output is mp3, 48000 Hz, 96 kbps, but changing audio output values doesn't make those options active as far as I can see.
  2. Explorer Case's Avatar
    Use a mencoder preset.
  3. Member ambrosechapel's Avatar
    That worked! Thank you. Good to know.
    sorry but i couldnt find the option that you talked about above(mencoder preset), where is it located on the ffmpegX window...thank you.
  5. Explorer Case's Avatar
    See this screenshot.
    thanks a lot!!
    I am also trying to boost the volume so I can hear better on an Archos media player. As suggested in this thread I have tried using mencoder and the "audio gain" setting but it does not have any effect. I set to max +9 gain but still no volume increase over the default setting. Am I missing something else? Source is VIDEO_TS (VOB, AC3) folder and I am encoding with DIVX mencoder preset. When I use DVDFab on a Windows machine I typically set audio gain to 250%. Would like to be able to get similar results with ffmpegX (or other Mac OS utility) if possible... in one step without having to separately demux/mux the audio.
  1. Increase volume of audio files
    By shans in forum Audio
    Last Post: 18th Feb 2012, 23:19
  2. Increase Audio Volume
    By Soixante in forum Authoring (DVD)
    Last Post: 25th Sep 2010, 16:24
  3. Replies: 3
    Last Post: 24th Oct 2009, 07:16
  4. how to increase the volume of the audio?
    By sharmine in forum Newbie / General discussions
    Last Post: 22nd Nov 2007, 05:45
  5. Trying to find a program I once had to increase volume on a audio file
    By natty in forum Newbie / General discussions
    Last Post: 18th Jul 2007, 14:57
