I've just started using ffmpegx on my Mac Mini core duo. I'm pretty sure that ffmpegx is using a recent stable version of XviD, such as 1.1.2. However, for several months now there has been a very stable version of 1.2 that includes SMP support. Does anyone know if:
1) is there a pre-built binary for OS X on Intel?
2) if there is (or one is compiled), would it work with ffmpegx?
3) where is the XviD binary currently located when ffmpegx is installed?
AR
Just an update that I see that the latest ffmpegx is using version 1.2 of XviD, from the log file:
xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
The question I have now, if anyone knows, is where do I set the number of processors (cores). The default is 0, which means one core.
AR
Trying to build x264 with NEON support for ARM platform
By sureshmenon87 in forum ProgrammingReplies: 0Last Post: 17th Feb 2012, 03:13 -
Can't Install .rm Support In ffmpegX
By bowjest in forum ffmpegX general discussionReplies: 19Last Post: 31st Jan 2009, 22:27 -
Please build support for 'nellymoser'
By kosso in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 23rd May 2008, 07:22 -
ffmpegX VC-1/WM9 support
By Thargok in forum ffmpegX general discussionReplies: 2Last Post: 21st May 2007, 12:03
Statistics
Newest guides
Latest tool updates
New media comments
