VideoHelp.com Forum
    Hi. I have a problem with burning backup dvd movies to my SOny DRX 710UL. I had already converted the movie files to less than 4.2G using DVDShrink and I am using a dvd-r disc. At Nero, when I had already added the movie folders and the "Fit to Record" is checked the NEXT button is grayed out and can't do anything anymore. I had tried re-installing it, reformat pc, used Nero Ultra 7 but the same problem exist. I read the Sony DRX 710UL is compatible with DVD-R and some posts shows that DVD+R is ok too. What could be wrong? Compatiblity issues? Thanks.
    Percy
    Why are you using "Fit to Record" ?
    There is a tool from nero for cleaning the tool completely out of the pc ... without trace .
    Uninstall nero , then clean it out using the tool , reboot pc , reinstall nero ... reboot and try again .
    You may also want too check for a firmware update for the drive , so as to have better support for new media .
    Could also be something to do with the media "batch" you currently have being of bad quality ... it happen's in all brand's .
    Try placing the media in the drive prior too running nero ... dont use the system default startup idiot user choice ... close that and actually run nero from it's shortcut after the drive has stopped spinning and see if it remain's greyed out .
    The system reformat was well overboard ...
    I know that that the reformat was way too much but I had other issues that's why I opted to reformat.
    Anyway, where can I find this "tool" that will remove any trace of Nero?
    Thanks.
    Percy
  4. DVD Ninja budz's Avatar
    Thanks.
    http://ww2.nero.com/nero6/eng/Clean_Tools.html
  5. Mod Neophyte Super Moderator redwudz's Avatar
    I will try it. thanks.
    Percy
  1. Sony HDR-CX150 HD issue
    By jtcarn in forum Newbie / General discussions
    Last Post: 20th Jun 2011, 20:33
  2. Replies: 2
    Last Post: 19th Dec 2010, 22:53
  3. Sony Vegas de-interlacing issue
    By Vman94 in forum Editing
    Last Post: 2nd Dec 2010, 00:17
  4. help Drx-710ul Doesnt Recognize Dvd+r
    By aqua in forum DVD & Blu-ray Recorders
    Last Post: 23rd Jun 2008, 22:57
  5. SONY DV DCRH21 issue
    By wingfan in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 11th Jul 2007, 00:41
