when i put the code 9735 it brings up the menu but will not allow me to arrow up to the region selection is there a password i need to enter so that i cant change it?
any help would be great
Same problem with mine mate... Hopefully somebody can help us !!
I try to call Conia, and even them don't seem to understand the problem...
Please, anybody got a clue?
Cheers
This may be stupid but there again often the stupid things can be just what's needed.
When you put the code in it will take you to the menu and position on the region code. You have to press the right arrow to move across to the region before you can then move up and down to select the region you want. Then when down, left arrow to move back to the option to exit menu.
Hi guys
I just discovered this one, it works for a variety of Conia DVD models with hard drive.
UNLOCK CODE FOR CONIA MR2501HD and a few models up:
1 switch off and on
2 in the numberic keypad type "0086000"
4 press enter, and a "0" should appear on the screen.
5 switch off and on using remote control and your away!!!
hope that helps, i discovered that this code will work for more than one model of Conia Hard Drive models! Good luck!
Yeah i am from sydney and i am having the same issue, i get the menu ...i see the region button but cant go up to it! i guess we got a dodgey model that wont let us change it?!
Dynex DX-UPDVD2 access the region code screen
By jfg in forum DVD & Blu-ray PlayersReplies: 0Last Post: 18th Jul 2010, 20:47 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 17:42 -
Virtualdub....An out-of-bounds memory access (access violation) occurred...
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 8th May 2010, 00:40 -
Conia M580 Problems
By Gavry in forum DVD & Blu-ray PlayersReplies: 11Last Post: 31st Oct 2008, 05:52 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 08:34
