Can someone send to me information on obtaining firmware for the Sony RDR-GX7 DVD Recorder? My Sony GX7 does NOT like DVD-R's over 8x. Please email me information to toledohamradio @ ya ho o . co m. THANKS. BTW, I have service manuals and service updates for this unit that I am willing to share with you if you can help me out with the firmware!
Results 1 to 15 of 15
Plz send firmware upgrade as well!!! I am in the same boat. medic746@mac.com
HELP!
I need new firmware updates too. Please send to bobp@d-o-c.us.
Thanks,
Bobbymustang
Have you guys tried Verbatims X16 DVD-Rs?
I have had no problems with using these with my GX7. TDK X16s worked for me.
Also, CC sells Nexxtech X8 that really are X4. These have also worked for me. I really only use Verbatims, so I've never had a media problem, besides about 4 discs my GX7 didn't like. I've made over 500 DVDs so far.
BTW, where were your GX7s made?
Mine is a early production made in Japan GX7, latter GX7s were produced in Malyasia. I've heard the made in Japan ones are better.
Pinetop,
Mine IS made in malasia. Not sure if there's anything I can do with it. I would think if I had the latest firmware from a Japanese model it might fix the cannot play disk error.
Bobbymustang
Heres another tip that may help you GX7 owners that are having problems with x16 DVD-Rs.
CC has new Nexxtech DVD-Rs these have newer packaging and state that their NX2. They say their x8, and they are. Prior offerings said x8, and were x4. Anyhow, I tried these and they do work in my GX7. They are UME media and are on sale for $8.99 for 50pk.
I've made two DVDs with this media and my GX7, I've also burned four DVDs, no problems so far. If ya don't trust UME, you could take the GX7 created DVD and burn a copy on your fav media with your PC. I would not hold my breath waiting for Sony to offer a firmware update.
Pinetop,
The Nexxtech DVD+R's are 8.99 and they don't work either. should I go back tomorrow and get the $29.99 DVD-R's?
Bobbymustang
Looks like you guys will be trolling for old crappy media.
The Nexxtech 8x DVD-R are identical UME media ID's to the older Playo 8x DVD-R (same media ID as 4x UMEs).
If you have the service documentation, it should have a recommended media list.
You can take it to the media list on this site and expand your universe to all of the media with the same mediaIDs and then troll the net and the clearance tables at retailers until you find a supply of something that is supported.
I don't think your SONY recorder uses a standard PC compatible drive so unlike with commodity recorders you can't swap it out. But certainly you should check. Perhaps the drive is something used in a PC which might be firmware upgradeable in a PC or at least swapable.
The Sony GX7 only records to DVD-R.DVD-RW. & DVD+RW.Originally Posted by bobbymustang
It will not record to DVD+R.
And in the Chicagoland area, Nexxtech DVD-Rs are $8.99 a 50pk.
Like so many people in this forum, I need firmware update. Please email to egoines2002@yahoo.com. Thanks alot!
If this firmware exists (for Sony RDR-GX7 DVD Recorder) , can someone email it to me or email me a link to it ? My email is:
"mondop@sbcglobal.net"
Can you please send me the firmware update to psauve@embarqmail.com?
thanks
Like so many people in this forum, I need firmware update to for the european version. Please email to mbjohanl@gmail.com. Thanks alot!
Firmware can be found at http://www.digitalfaq.com/forum/show...-gx7-1877.html
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
The firmware is here:
http://groups.google.com/group/techassist
Version 1.30 and is only for USA units. That is all I have. Do not ask for any other. If someone has access to Sony ESI service then PM me. I'd like to get a user/pw if possible. thanks!
BTW - this fw supposedly only corrects a DISK EJECT problem with "self burned" DVDs. If you are handy with firmware you might be able to hack some new media codes / speeds in there too. This is funky firmware. Good luck!
Sony RDR-GX7
By joecass in forum Newbie / General discussionsReplies: 3Last Post: 16th Dec 2009, 18:53 -
Sony RDR-VX535
By john god in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Nov 2009, 18:51 -
Is Sony RDR-HX720 compatible with Sony HT-SS2300
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Nov 2008, 09:14 -
Sony RDR GX7
By Macdon22shippTWO in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Sep 2007, 11:55 -
RECOVER DVD - Power Failure Sony GX7 ?
By johnnyelectron in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th May 2007, 11:13
