VideoHelp.com Forum
    when i convert avi,mpeg,ect to scvd,vcd,and dvd and burn them,and play
    it on my dvd player,that is hook up to my tv,the movies are like kinda
    slow,but when i play the avi,mpeg,ect on my computer it works great,
    it is like real,but when i play it on my player,is slow,and now it is boring
    to watch.like is slugish slow,dont look like the movie I have in avi or mpeg format.
    is there a special code to install to convert or burn a certain brit,ect? please I hope
    someone know what i mean....I can send a sample of the avi and svcd and you can
    see the differnt.
    I been using Aurora Media Workshop,WinAVIVideoConverter and Video Convert Master
    and it is the same way, i am using memorex cd,s...I have tried dvd players on my
    computer too,and it plays the same on them too,weird that before I convert them from
    avi or mpeg it plays in those format great...any ideas for me to try? do you konw of
    any other converters for me to try and what settings shall I set them for? and what
    disk it the best to burn them on? sorry for so many questions
  2. Mod Neophyte Super Moderator redwudz's Avatar
    That doesn't sound like a disc problem. Try ConvertXToDVD instead of WinAVI and some of your problems may go away.
    Drop one of your converted videos into Gspot 2.60 and see what it says. Look for the framerate (fps) Are you sure you are outputting to the NTSC standards? Look to the upper left on this page for 'WHAT IS' DVD for the DVD specification and format.
    MPEG-2 Program Stream << { 1 vid, 1 aud }
    Sys Bitrate: 2793 kb/s VBR
    frames/s 29.970
    pics/s 29.970
    kbps 2520
  4. Mod Neophyte Super Moderator redwudz's Avatar
    That bitrate is very low for a DVD. It might be acceptable for 1/2 D1 format. (352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)) Most DVDs would have a bitrate up around 5000 kbps or higher. I don't think that would cause slow playback, just poor quality video.
    The framerate seems OK at 29.970 fps. Is the AVI framerate the same or did you do a framerate conversion somewhere?
    How long is the video, I mean playing time? If I plug your bitrate into a bitrate calculator, it shows a playing time of about 3 1/2 hours at 2600 kbps bitrate to fit to a regular DVD. http://www.videohelp.com/calc.htm A two hour DVD should have a bitrate of about 4800 kbps.
    I am trying svcd format on my cd.those I showed you in from
    scvd format,not dvd,but dvd is the same way on play back.
    480x480. I cut a few min from the avi to test the scvd format
    I will see if the frame rate is the same. avi fram is 23.976
    the scvd is 29.970.i dont know how to do a framework conversion
    1 min 18 sec long
    any ideas what I can do next? because I really want to make
    this work out,because I have tons of movies I want to burn
    eith on cd or dvd,but I make sure we get this corrected
    somehow and what im doing wrong.
  1. NTSC DVD player that allows you to slow down playback speed?
    By eurotimes2 in forum DVD & Blu-ray Players
    Last Post: 31st Aug 2011, 00:46
  2. Slow play of Movies
    By miguel.domingos in forum Software Playing
    Last Post: 8th May 2011, 03:20
  3. Replies: 2
    Last Post: 25th Nov 2010, 20:28
  4. Is my dvd player able to play Hd movies
    By maxshot in forum DVD & Blu-ray Players
    Last Post: 19th May 2007, 05:01
  5. Convert movies for a settop DVD player?
    By harleytio in forum Newbie / General discussions
    Last Post: 6th May 2007, 16:05
