VideoHelp.com Forum
  1. I primarily use a DV camcorder and a 1394 card to get video into Premier 6 for editing. I usually pull the video in as uncompressed AVI for Premier. Output is sometimes back to DV or VCR or mpeg. Now the problem. I routinely have to cut various setting below what I would prefer because I get errors inputting or outputting from Hard Drive. I understand that video needs from 30 and higher MB/sec sustained transfer rate to and from the HD. I do NOT want to go to SCSI so I have been unable to find a HD with those sustainable data transfer numbers. I have been told that an IDE RAID system (PCI RAID controller) with 2 or more nominal IDE HDs will solve the problem. However, someone else said I wouldn't see much data transfer improvement with an IDE RAID system. I come to you for help - simple truths please (or not so simple as the case may be <g&gt.
  2. I think it depends on how you configure your RAID. Redundant RAID won't improve transfer rates but does improve data security, whereas striping can gain you 1.5-2x the transfer rate (I think). I have no actual experience with it, though, so I will leave further discussion to others.
  3. Yes, it is stripping I must use - thank you for pointing that out. Anybody with real world experience? I must know this before I can determine which (and how many) hard drives to add to the system.
  1. Replies: 15
    Last Post: 30th Nov 2009, 08:35
  2. Sony AVCHD transfer to computer hard drive
    By jal79 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd Jul 2009, 14:21
  3. Replies: 11
    Last Post: 23rd Jun 2009, 16:54
  4. How do I transfer shows recorded to hard drive to DVD?...
    By Tigergreg in forum Newbie / General discussions
    Last Post: 4th Mar 2008, 19:35
  5. Transfer miniDV to hard drive. Does it matter what software is used?
    By vid83 in forum Newbie / General discussions
    Last Post: 11th Dec 2007, 19:08
