Im looking for a dvd player that has a built in tv tuner. The reason for this is, i wish to use a hdmi-dvi converter in order to watch dvd's and tv on a lcd monitor. Does such a player exist?
Thread: HDMI DVD player with TV tuner?
LG LST-3510A HDTV Receiver & Upconverting DVD Player
That's great, thanks for the info.
I really don't need the HDTV receiver capability, and would prefer a cheaper more widely available one.
Ideally I would like to find one that can also can play divx files.
Technically, you are looking for a TV receiver such as a DVR, Tivo, etc. that has a built in DVD player. So the best play to start looking depends on your TV service (antenna/cable/SAT).
DVD players, as the name implies, are for playing DVD's.Google is your Friend
The TV service is cable (non-digital). TV receiver with DVD playing capabality, that also plays divx would be ideal. Thx for pointing me in the right direction.
Since you are only needing VCR type support, take a look at the various DVD Recorders: http://www.videohelp.com/dvdrecorders
If you do ever need digital/pay channels/HD, you will of course need different hardware.Google is your Friend
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / HDTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
When you use a PC tuner to HDMI TV input, what causes artifacting?
By MarcMiller in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Aug 2011, 20:27 -
Pleading for guru advice DVD recorder w/digital tuner, hdmi
By arlene in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Nov 2009, 10:55 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / HDTVReplies: 1Last Post: 25th Apr 2009, 09:40 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 12:35
