I have discovered this technique for getting into the service menu of my DVP-NS725p player but have not been unable to make any changes once in there. Any help as to how to change settings once in there would be appreciated.
Here is what you do to access the menu.
1. Turn off player with power button.
2. Press TopMenu button, then Clear button, then Power Button.
3. When unit powers up you will be in the Service Menu.
4. Pressing any of the listed item's numbers will get you into that submenu.
5. Pressing 0 will back you out of that submenu.
6. Pressing Power button from the beginning service menu will get you out and back to normal mode.
Thread: Sony DVP-NS725p Hack
to stmsds,
The hacks mentioned at your link do not work on the 725p, I am interested in info on how to use the service menu to effect changes in the 725p's performance as to region and macrovision which are right in the service menu. I just don't know which buttons on the remote access them.
jacksrepairs, I am also searching for DVP-NS725P to make region free.
I found that your procedure at least show the menu, I tried couple of options but I can't able to find how to change the region.
If I found I will post it here, but if you already found please update this post.
I had a similar problem before but with a different brand, I found a solution in this tech support website. I am sure they can help you also!
Here is the page for Sony DVP-NS725P Support
Just ask a question or use the live chat, its free!
Let me know what happened cause I curious...
Jon
Are you looking to make it "Region Free" to play original pressed import dvd's or are you trying to make it play PAL formatted dvd's ?
Because by backing up original pressed import disc's will effectively make them region free, however, if they are PAL that's another story as Sony players in the U.S. are notorious for NOT converting pal to NTSC, or even displaying/playing PAL disc's even if you had a TV that will display PAL video.Originally a member since 2001, LONG LIVE TARAN's!!!
jonst and Noahtuck
Thanks for reply.
Jonst, I will look at the site which you suggested, someone else already asked my question, so I will see the reply.
Noahtuck, I have NTSC Format DVD, but from different region, so I need to make it region free.
Region Hack for Sony DVP-SR500H?
By Tank251 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Mar 2012, 07:47 -
Can anyone help me hack my Sony DVP-NS700H? Thanks.
By JZJ in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Dec 2010, 20:36 -
Hack Code for Sony DVP-NS710
By pmanfredi in forum DVD & Blu-ray PlayersReplies: 4Last Post: 24th Feb 2010, 21:24 -
All Region Hack for Sony DVP-NS708H -_-
By BloodySunday in forum DVD & Blu-ray PlayersReplies: 2Last Post: 23rd Nov 2009, 07:44 -
Hack on Sony DVP-NS700P
By bordterr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jun 2009, 07:31
