  1. I searched for an answer to this, but it was not addressed. I am trying to install v. 009k on a laptop. I downloaded the files and stored them in a folder called "ffmpeg binaries" in the applications folder. I selected all the files in the installation directory, but I get the following error message:
    ##/bin/sh: line 1: cd: /usr/local/include: No such file or directory
    Is it because I am trying to install an older version of ffmpeg?
    thanks for the help
    If that directory is really called ffmpeg binaries, and not ffmpeg_binaries or some such thing, that's your problem. The installer is fussy about special characters (and that includes spaces) in the pathname. This is a very common problem.
    I have a similar problem when trying to do the _required_ update of ffmpegx.
    The Self-Installer doesn't see the binaries at all(!) in the ffmpegx folder I placed them in!
    The instructions do say the hard drive can't have spaces, well how can I change that without losing anything else that relies on the traditional "Macintosh HD" (space, no underscore)?!
    The application is now useless, and I have come to depend on it!
    HELP!!!
  4. Explorer Case's Avatar
    Place your three binary files on the desktop. Use the Locate button to point the installer to them. The paths then become
    /Users/username/Desktop/mpeg2enc
    /Users/username/Desktop/mencoder
    /Users/username/Desktop/mplayer
    which might be enough to make it work, as the volume name now isn't part of the path.
    The binaries are copied by the installer, so the original files can be removed afterwards.
    You could try changing the boot volume name, install the binaries, then change it back to what it was. Worth a try, don't you think?
  1. Error on installation
    By Metrazal in forum SVCD2DVD & VOB2MPG
    Last Post: 6th Dec 2005, 11:17
  2. Installation error under 10.3
    By NancyS in forum ffmpegX general discussion
    Last Post: 11th May 2005, 21:07
  3. Sorry, yet another installation error (v0.0.9r)
    By RadioDog in forum ffmpegX general discussion
    Last Post: 23rd Jan 2005, 18:22
  4. Installation Error
    By aznraver1022 in forum Newbie / General discussions
    Last Post: 9th Jan 2005, 08:18
  5. Error on installation
    By dmshimself in forum SVCD2DVD & VOB2MPG
    Last Post: 24th May 2004, 02:31
About   Advertise   Forum   RSS Feeds   Statistics   Tools
