VideoHelp.com Forum
    How can I edit my project (preferably in dvd-lab pro) so that a set chapter point links back to the chapter selection menus after playback?
  2. Member GeorgeW's Avatar
    Insert a CHAPTER Playlist that only has the one chapter, and make the menu button link to the Chapter Playlist (default name will be Branch xx). The End-Link for the Chapter Playlist should be your menu...
    Regards,
    George
    What exactly do you mean, I'm confused. I have 8 chapters. Before one chapter plays into another I just want it to go back to its respective chapter selection menu.
  4. Member GeorgeW's Avatar
    In the CONNECTIONS window work space, rt-click/Add/Chapter Play List (this will add an object called Branch 1). Double-click the Branch-1, and add the chapter(s) you want to play (can be one, can be multiple in different order from the same movie title, etc...). Then your menu button should link to that BRANCH. Also change the End-Link of the BRANCH object to go back to the menu.
    Regards,
    George
    Thank you George you just helped me finish my project!
  1. Replies: 9
    Last Post: 16th Feb 2012, 18:04
  2. Replies: 1
    Last Post: 26th May 2010, 09:32
  3. Return to Title - NOT Chapter Menu - HOW?
    By jlrm365 in forum Authoring (DVD)
    Last Post: 13th Mar 2010, 21:15
  4. How to add a chapter or a title to ONE ONLY TITLE in a DVD?
    By coxanhvn in forum Newbie / General discussions
    Last Post: 27th May 2009, 22:16
  5. Make title to chapter
    By gameroftheuk in forum Newbie / General discussions
    Last Post: 18th Aug 2008, 15:03
