hey
my default player for all my video files on my hard drive was power dvd but for some reason its switched to media player-and for some other reason it cant play a lot of files that power dvd could.
I completely forget how to get it back the other way around??
i went to properties of my dvd drive and it didnt even have power dvd in the list for video files, yet it still plays as default player for dvd discs
Please help!
Cheers
Thread: choosing default player
Try right-clicking on a particular file and going to Open With .... Then go to Choose Program, then choose PowerDVD, and tick the "Always use the selected program to open this kind of file" box. This should fix the file association for that particular file type. Rinse and repeat for any other file types affected. If that doesn't work, go to windows explorer, and go to Tools > Folder Options > File Types, find the extension(s) you wish to change and click the "Change" button. You should then be able to choose PowerDVD, and again tick the box so that it will always use powerdvd to open files with that extension.
If in doubt, Google it.
did you just upgrade WMP? if so, thats why. you can open media player and select tools/options/file types and DEselect dvd video, so wmp doesn't consider itself the default.
I am just a worthless liar,
I am just an imbecil
Choosing DVD Player ???
By Tukun in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jan 2006, 13:55 -
Subtitle default varies player to player
By DeadLily in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Dec 2004, 20:35 -
Choosing a DVD Player
By msalem in forum Newbie / General discussionsReplies: 25Last Post: 9th May 2004, 02:31 -
Help Needed In Choosing DVD Player
By ManWithaPlan in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Mar 2003, 11:13 -
Making Windows Media Player the default video player for you
By mikewg in forum Software PlayingReplies: 7Last Post: 8th Nov 2001, 02:37
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
