VideoHelp.com Forum
    I want to be able to watch stuff on my Xbox 360 using my PC and either Zume or Tveristy.
    I have a bunch of avi's and divx...but the 360 can only view wmv files.
    I have winavi...but it won't convert everything. Some avi's it has worked...others cause the program to crash without warning.
    What's the best way to do this? I can watch the stuff on my PC monitor..but I want to use the XBOX360 and my big screen TV.
    thanks for helping out a newbie.
    Nit
  2. Member FulciLives's Avatar
    If you have a lot of DivX and XviD AVI files then the simple solution is not to convert (which can take ages and degrade the quality) but to buy a MPEG-4 capable DVD player so that you can burn the AVI files to CD or DVD and just play them "as-is" on the DVD player.
    The Philips DVP-5140 can do this and is relatively cheap ... WALMART sells it for just under $50 US Dollars.
    - John "FulciLives" Coleman
    thanks...but can the xbox 360 play those types of DVDs?
  4. Member FulciLives's Avatar
    I don't know much about the XboX 360 other than you just said that it will only play WMV files.
    I know there is a way (I don't know the details) to stream from the PC to a regular Xbox and in that way you can play MPEG-4 files such as DivX and XviD files. I don't know if this is possible with the Xbox 360 but I know that you needed a moded Xbox to do this so I assume you to need to mod a Xbox 360 to do the same if it is possible.
    You are probably better off seeking a forum group dedicated to gaming consoles than a video site like this one.
  1. Converting MKV to WMV for the XBOX360
    By zilbermm in forum Video Conversion
    Last Post: 29th Oct 2009, 09:29
  2. Converting WMV to burn on DVD to play on DivX
    By ez2cy in forum Video Conversion
    Last Post: 20th Dec 2008, 03:54
  3. Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
    By snadge in forum Video Conversion
    Last Post: 8th Jan 2008, 05:48
  4. Help converting home movie dvd to avi/wmv for web
    By dancingbear0420 in forum Newbie / General discussions
    Last Post: 24th Aug 2007, 13:35
  5. Adding chapters to WMV file for use on Xbox360
    By brijazz in forum Video Conversion
    Last Post: 30th May 2007, 07:11
