I'm transferring VHS tapes to DVD, and would like to know how I can set up chapters. Also is it not possible to edit the commercials whilst transferring? How do you transfer two videos to DVD?
For some strange reason we aren't getting the time displayed, is this normal?
Thanks for any help as I am pretty much a novice.
Cheers
Thread: Panasonic DMR-ES35V
If your recorder has a HDD you should be able to edit in chapter points. If it doesn't, and your transfer is straight 1:1 real time, you're out of luck.
Putting in chapter points requires that you do "non-linear editing", which means after the fact. The only other thing you could do is get a capture card for your PC, capture the VHS material, then edit>author>burn, adding the chapter points.
Panasonic DMR-ES35V
By RobJenk in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Dec 2010, 13:42 -
use Panasonic DMR-ES35V with universal remote?
By kar120c in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Sep 2010, 14:14 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 17:50 -
Panasonic DMR ES35V DVD NoRead repair
By Lumpy2 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 4th Jun 2009, 03:00 -
help for PANASONIC DMR-ES35V ......PLEASE!!!!
By samjc2007 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Jul 2007, 11:35
Statistics
Newest guides
Latest tool updates
New media comments
