There is nothing in the manual for the recorder on this button other than a layout of the remote that says it is for inserting chapter marks during recording.
While recording I pushed the button where I want a new chapter to start but there was no visual indication that it did anything. After finishing the recording (before finalizing) I went to the Edit and there was no chapters other than the one main one.
Can you create chapters with this button? Or what is it really supposed to do?
Thanks !
Thread: Toshiba D-R5 CHP Divide?
It only works with RAM discs, or maybe RW in VR mode. You can set the recorder to make chapters at 5, 10, 15 minutes on RW and R.
When I went back into the "Edit Menu" while playing the recorded dvd it does look like it created chapters using the "CHP Divide" button during recording.
Next question.... can you rename chapters using the recorder or should I try editing the chapter names on the computer?
I can on the D-R4, but someone else here said the R5 doesn't do it. On the R4, you go into easy navi and select play, then quick menu and select create thumbnail.
Import .chp list from ChapterXtractor to Maestro error
By rbatty11 in forum Authoring (DVD)Replies: 2Last Post: 13th Aug 2007, 12:20 -
Where do I get a chapter file (*.txt;*.chp;*.eds_chpt) from?
By DRP in forum Authoring (DVD)Replies: 1Last Post: 4th Mar 2005, 04:57 -
DVD Maestro error importing .chp chapter list.
By Doggiedaddy in forum Authoring (DVD)Replies: 4Last Post: 10th Apr 2003, 12:46 -
.m2v, .ac3, .chp - what now???
By jpd3 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jan 2003, 00:15 -
help importing Chapter Extractor (.chp) file into Maestro!
By masterpug in forum Authoring (VCD/SVCD)Replies: 0Last Post: 2nd Dec 2002, 17:25
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
