Have a short MP4 video clip (for iPod) with mono audio track which I want to replace with stereo audio track.
In QuickTime Player (Pro) 7.1.3, the Properties of the video file shows that the video component is MPEG-4 and the audio component is AAC.
If I select the audio track in this window, the Delete button highlights, so it seems straightforward how one deletes an audio track. But how do you add another one? What format must it be (bit rate? sample rate? etc.) to be compatible? (The stereo audio track I want to add to the video is currently mp3 format but, of course, I can convert this to AAC using iTunes or other application.)
Would like to know if I can do this edit within QT or if I need another app. Prefer 1) freeware, 2) shareware, 3) inexpensive commercial apps. Beyond that, probably it will become quickly not financially viable.
Any suggestions, step-by-step instructions, or encouragement welcome.
Thanks,
JJ
OS X 10.3.9; QT Pro 7.1.3
If you alreday have Quicktime Pro, this is pretty straightforward.Originally Posted by jojo8
1/ Open your mp3 file in QT.
2/ Choose "Edit" > "Select all"
3/ Choose "Edit" > "Copy"
4/ Open your mp4 video clip and be sure the cursor is at the beginning of the movie
5/ Delete the mono audio track
6/ Choose "Edit" > "Add"
7/ Go in "File" > "Export..."
8/ Choose MPEG-4 and click on "options"
9/ Choose "Passthrough" for the video codec
10/ Choose AAC-LC, 96 kbps, Stereo, 48 KHz, Best
11/ Save the new file at the desired location
The stereo track has to be the same length as the original mono track, else you will experience synchronization problems.Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
Replacement audio track is shorter, so I added silence at the end to make it same length as the video.
Result is that sync problem occured -- audio arrives early before lips move.
What do you suggest I do to make audio sync with video?
In QT, there are 2 Add options: Add To Movie, and Add To Selection & Scale. I have used only Add To Movie. Should I use Add To Selection & Scale?
Thanks,
Dave
Just a note that if your goal is to play the end product (after all the issues are resolved) on an iPod, the audio is going to be in the wrong format if you convert to mp3. iTunes won't sync it.Originally Posted by jojo8
What do you suggest I do to make audio sync with video?Originally Posted by jojo8
You'll have to add silence at the beginning of the audio track in order to keep it in sync with the video. Unfortunately there is no other method to guess the exact amount of silence than doing a manual fine tuning. Try something like 100ms increments.
Open the audio and the video track with Quicktime and use the menu command "Play All Sequences" (command-return) to check the synchronization.
This probably won't do better : Instead of having, say, 0.1 s of constant desynchronization, you'll get variabe desynchronization throughout your movie.In QT, there are 2 Add options: Add To Movie, and Add To Selection & Scale. I have used only Add To Movie. Should I use Add To Selection & Scale?Jean-Philippe Schuck
Replacing DVD Audio track (how does this sound?)
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2012, 15:00 -
Replacing a DVD audio track
By mltwitz in forum DVD RippingReplies: 2Last Post: 13th Jun 2010, 19:58 -
A little mess in replacing audio track
By Instant Martian in forum DVD RippingReplies: 2Last Post: 12th Mar 2010, 17:59 -
Replacing an audio track in an mpeg
By lordhutt in forum AudioReplies: 1Last Post: 14th Oct 2009, 19:39 -
Replacing audio track query
By Dizrythmia in forum DVD RippingReplies: 3Last Post: 26th Jul 2008, 11:51
