What is size of standart DVD cover art in pixels? In other words; what the size should be, that it would fit just fine to empty dvd case?
Results 1 to 27 of 27
Thread: DVD cover size and paper
Standard Cases
Single Amaray 3240 x 2175 (170 spine) ThinPak Single 3150 x 2175 (80 spine)
ThinPak Single 3170 x 2175 (100 spine) ThinPak Double 3180 x 2175 (110 spine)
Slim Cases
Slim 3-4 3240 x 2175 (170 spine) Slim 5-6 3370 x 2175 (300 spine)
Slim 8 3395 X 2175 (325 spine) Slim 10 3460 X 2175 (390 spine)
Double Amaray 3305 x 2175 (235 spine) Triple Amaray 3384 x 2175 (314 spine)
4-5 Disk Alpha 3508 x 2175 (438 spine) 6-7 Disk Alpha 3661 x 2175 (591 spine)He's a liar and a murderer, and I say that with all due respect. -
You need 3240 x 2175.
That size is HUGE in pixels. Way too big for dvd case.
Try this template -
template_single.zipHe's a liar and a murderer, and I say that with all due respect. -
Excuse me, but how could that fit to dvd case? Am i missing something?
I don't have printer at home. -
steveryan is likely suggesting a 300dpi standard photo quality print size.
If you're working at 72 dpi, convert it by dividing the dpi by 300, then multiplying by 72;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
A pixel is not a real world unit.Originally Posted by Digiface
You need to know the DPI (dots per inch) to get a real size.
eg, 600 pixels printed at 300 dpi is 2 inches. Printed at 600 dpi is one inch; at 75 dpi is 8 inches.
Also, there are several different size DVD boxes, and you can also use CD boxes, the boxes are smaller but the discs are the same size so they fit.
Many burning apps seem to come with cover printing modules for some standard size boxes, you can import just about any image to these. They should scale to fit and as long as not really low res should print okay. -
Is this good paper for DVD covers? http://riemun.huuto.net/auctionimages/2/b3/83124e3cbf9d48f64a19718677ae1-orig.jpg
Exactly.Originally Posted by steveryan
Use the above template if you are creating from scratch....then Google
MultiCoverPrint software....that is my method anyway.
I have used Nero cover designer.
Edit. I just downloaded that MultiCoverPrint. So i just add cover, that i downloaded from cdcovers.cc and print it? Does it then print it to right size for 14mm DVD case? -
It prints to a normal sized DVD case....just like 99% of the cases bought, sold and used by the industry.
Use a piece of plain paper....print one at very low quality as a test, cut it and test it on a normal sized DVD case.
It works perfectly for me every time when I do it from scratch with the template and MultiCoverPrint and with covers sent to me by others.
If you are in Finland....you have the advantage of A4 paper...you are already one step ahead of Americans(which I still am....but I live in Europe).
I quote myself. So is it? I have Canon iP1700 printer.Originally Posted by Digiface
Edit. Don't you have A4 paper in USA? -
[quote="Digiface"]
Yes and no.....it's hard to explain....Originally Posted by Digiface
We have Legal size...8.5 x 14 inches...but
for some reason I still don't think that is A4
exactly.
I use HP Brochure paper for my covers....but I have
nothing but HP printers.
A4 is 8.3 x 11.7 inches
I think therefore the usa letter size is probably nearest (8.5 x 11.0 inches) -
Normal letter sized paper in America is 8.5 x 11 inches....this is the most common size.
Legal is supposed to be 8.5 x 14.
Does matte paper eat more ink than glossy paper? And if so, how big the difference is?
Since DVD cases have clear plastic that covers the print, it is better to use the cheapest paper you can buy at normal (or fast normal) setting. You'll use less ink which is the most expensive material that you will use in this process. Yes, more expensive than the discs or the cases.
My old HP printer would not print to edge so I had to use legal paper which was 20# paper but my new HP printer will print to edge so I use any 24# 8.5 x 11 paper that is on sale.
For CD cases, I use 90# or 110# bristol or card stock. -
Not sure....but I do think that MultiCoverPrint throws out WAY too much ink. I use normal quality settings with that program. I'm not even 100% sure that MultiCoverPrint is capable of "having a say" in how much ink is used....but it sure seems that way to me...Originally Posted by Digiface
I could be wrong.
Yesterday i printed 18 covers to Canon 190 glossy photo paper. On 13th cover it started to notify that color ink is running out. On final 18th cover, colors were already unsharp/lame. I printed with "normal " quality and color cassette was almost unused.
Anyway, the result of covers was very, very retail like.
Is it normal that black color is very grey when printing to matte paper?
Seems that other manufactor than Canon papers doesn't work with my printer (Canon iP1700). Is this common?
I'm using www.printdvdcover.com for a while now, it's simple and free of charge. You can print DVD, Blu Ray or Jewel case covers with it. The output is PDF so you can use it on every platform, also a MAC!
On the website you can also download JPG templates for creating your own covers. -
WTF is up with this rash of grave robberies lately?....holy crap. This thread is 5 years old and the last post in this thread was 4 years ago.
Make it simple... use this site... generate the pdf and print afterwards
it takes 1 minutes and you get a perfect copy
http://www.printdvdcover.com
What's some good paper for DVD inserts?
By slayerbizkit in forum MediaReplies: 13Last Post: 21st May 2011, 09:01 -
Dvd Cover Size?
By Denvers Dawgs in forum Newbie / General discussionsReplies: 8Last Post: 4th Aug 2009, 18:05 -
Pre-perforated paper for DVD case labels?
By stantheman1976 in forum Newbie / General discussionsReplies: 6Last Post: 27th May 2009, 12:40 -
DVD Covers - What Paper?
By Nitro89 in forum MediaReplies: 12Last Post: 15th Apr 2009, 18:02 -
Best paper for cover printing?
By SilverBlade in forum MediaReplies: 31Last Post: 4th Jun 2008, 21:01
