Can someone please point me to where I can find settings to convert a VOB file to PSP.
I used Mactheripper for the VOB and I am using ffmpegX to convert. I tried to use the PSP setting in ffmpegX, but it didn't work.
Can someone please help?
Mac OS X 10.3.9
Dual 2Ghz G%
1.5 GB mem.
PSP Firmware 2.71
Kind of a newbie, but learning fast.
Thanks in advance
Thread: PSP settings
Please describe what the results were. Did you file get converted or not? Did you get an error, if so, which? How large was your output file? Could you play the converted file on your Mac? If the conversion failed, please post the log.Originally Posted by tbrend
I transfered the file to my PSP and tried to play it. I got the error message "This video cannot be played"
The file was converted. No errors. The name is M4V02395.MP4. It size is 36.5 mb
Here is the log from ffmpgX —
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mpeg, from '/Users/timbrend/Movies/THE_MATRIX_16X9LB_N_AMERICA Title 1 (Ch1 - Ch2)/VIDEO_TS/THE_MATRIX_16X9LB_N_AMERICA Title 1 (Ch1 - Ch2).VOB':
Duration: 00:03:09.9, start: 0.026122, bitrate: 11567 kb/s
Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 7500 kb/s
Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
Stream #0.2[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.3[0x81]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, mp4, to '/Users/timbrend/Movies/THE_MATRIX_16X9LB_N_AMERICA Title 1 (Ch1 - Ch2)/VIDEO_TS/M4V02395.MP4':
Stream #0.0, 23.98 fps(c): Video: xvid, yuv420p, 640x352, q=3-9, 1213 kb/s
Stream #0.1: Audio: aac, 24000 Hz, stereo, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
video:35758kB audio:1551kB global headers:0kB muxing overhead 0.399440%
bench: utime=290.750s
1 video MPEG-4 Unknown Profile(0), 387.220 secs, 0 kbps, 640x352 @ 23.98 fps
Warning:fps must 14.985 or 29.97.
2 audio MPEG-4 AAC LC, 395.989 secs, 0 kbps, 24000 Hz
Ready.
Try encoding with the framerate at 29.97 fps.Originally Posted by tbrend
"Try encoding with the framerate at 29.97 fps."
Where exactly do I enter that? Under video? When I did that, I got an error saying it couldn't create an interger.
You can select the framerate in the drop down menu. But using the PSP preset should set the framerate initially at "NTSC (29.97)".Originally Posted by tbrend
Also read the how-to webpage. "width x height must not exceed 76,800 pixels", but your 640x352 = 225,280 is almost 3 times over this limit.
I used the settings that you gave me and it worked! However, the audio isn't in-sync in some places and others the directors audio is played.
When I preview or play it in ffmpgX, the audio is good and everything looks fine.
When I make the VOB from Mactheripper, I am only selecting a couple of chapters so it doesn't take to long. Does this have anything to do with it? Should I do the whole movie and not just a chapter?
Thanks again
XVID4PSP -- what are the best settings to convert ripped VOB files to PSP?
By WaverBoy in forum DVD RippingReplies: 4Last Post: 5th Feb 2010, 09:22 -
Best settings for psp
By str3am in forum Portable VideoReplies: 2Last Post: 21st Jan 2009, 13:00 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13
