VideoHelp.com Forum
    I recently updated my Nero Express to version 6.6.1.4 and I successfully burned one vcd with no problems at all, but when I tried to compilate another one (either VCD or SVCD) window (2k) says "nero.exe has generated errors...", while with other options like audio, data or DVD video that doesn't happen.
    I didn't install any new software, didn't change the configuration or make any significant alteration in my system, so I'm totally lost here.
    I even uninstalled Nero (with the proper cleaning tool and 2 registry cleaners) and reinstalled it, with the same results.
    I wrote to Nero technical support about a week ago but so far they haven't contacted me. I tried reading the nerohistory.txt file but what I little understand of it, it seems to be a registry permission problem (even with administrator rights on), but I'm not sure. It might be something else. Please help me!
  2. Member Krispy Kritter's Avatar
    Have you only tried making a disc using the same files or have you tried different files? It could just be an issue with the files you are trying to convert/burn.
    Google is your Friend
    Try the ms installer cleanup tool ... seems there might be an issue with the registry permission setting ...
    http://support.microsoft.com/kb/290301
    I can't even choose the file I'm gonna burn, the compilation window closes at the same time the error message appears (and sometimes it doesn't, the message just pops up after I click on the VCD or SVCD option in Nero StartSmart).
    I'm gonna give it a chance to the MS tool, though I used Nero's own cleaning tool and everything resulted in the same... But what if it's an issue with the registry?
  5. Member Krispy Kritter's Avatar
    I expect the ms tool is to correct a registry issue. If that doesn't work...
    Actually I'm a little afraid to use that tool after I read the especifications, it says that it might risk other programs and have to reinstall them. It is a bit dangerous to use that tool, isn't it?
    So I ckicken out and used Nero's cleaning tool again instead. I thought, 'maybe I did something wrong last time'. Well, it worked! What was different this time around? Before, I uninstalled Nero normally (from Windows) and THEN used the tool. I know, it was totally stupid. This time I used the tool first, then reinstalled Nero and now (S)VCD is functional again.
    Thanks for your help, it was really appreciated!
    Education is the inculcation of the incomprehensible into the ignorant by the incompetent.
  1. Video Compilation
    By redcapeman in forum Editing
    Last Post: 27th Dec 2010, 05:01
  2. DVD compilation.
    By Benhermies in forum Newbie / General discussions
    Last Post: 6th Aug 2008, 11:46
  3. CD Copy with Nero Fails after a few burns
    By kadzbiz in forum Media
    Last Post: 5th Feb 2008, 19:46
  4. Suggested program for compilation ???
    By Kev90 in forum Editing
    Last Post: 17th Jul 2007, 01:08
