I think I'm breaking my camcorder using it to supposely caliber the tension of the tape by rewinding then forwarding and rewind each time I want to transfer some tape. I also have to rewind the tape using the camcorder "to keep tensions stable I suppose"; each time I want to redo a not so good transfer.
Is it possible to use the VHS adapter to rewind it on my VCR or can I use a standard rewinder will that cause tensions again is it safe?
If I can use a rewinder what type? What usually cause timebase problems... manual rewinder?
When I played this VHS-C on my VCR using the adapter, it it causes distorted images at certain points on the DV capture.
Results 1 to 1 of 1
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum CapturingReplies: 0Last Post: 19th Feb 2012, 15:52 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 17:18 -
Do I need a remote control to program TBC/3R etc functions in JVC HR-S7955?
By leon43 in forum RestorationReplies: 1Last Post: 14th Dec 2008, 07:04 -
VBI control using Sony mpu-f100a frame memory unit (TBC)
By crosstalk in forum RestorationReplies: 0Last Post: 11th Jul 2008, 12:15
