VideoHelp.com Forum
Page 2 of 2
FirstFirst 1 2
Results 31 to 50 of 50
  1. I have done the above process for recording a live streaming using VLC 1.0.2, but the error is here
    Your input can't be opened: VLC is unable to open the MRL 'mms://stream.securewmlivesvc.vitalstreamcdn.com/live_secure_stream_geo_tv_geovideo'. Check the log for details.
    Kindly help for this issue. Thanks a lot in advance.
    VLC does not support all mms streams like drm encrypted.
    You have try other tools to record the stream, http://www.videohelp.com/tools/secti...ming-recording
    Originally Posted by nathanbrauer View Post
    Here is the up-to-date screenshot instructions on how to save video streams (or mms:// videos) to a file using VLC Media Player.
    This uses VLC 1.0.0 but should work the same in the new 1.0.1.
    Thanks-
    This worked great on a MMS stream of a .wmv file
  4. I'm having difficulty recording this stream:
    mms://wms3.visionip.tv/RevelationTV?MSWMExt=.asf
    Can anyone help? Records the audio but not the video...
    Hi
    I am an orthopedic surgeon in prague and would like to capture streaming video from The University of Arizona using vlc
    the link is mms://stream08.ahsc.arizona.edu/video/2009/06/22/SMC2009_06_22.wmv
    Thanks for the help
    Nicholas
    I use vlc player to stream and it works great
    I tried using VLC 1.1.1 to download mms video streams but it always crashed or only downloaded the audio, so I tried Net Transport and voila - perfect results every time.
    It has a drop box which makes everything so much easier as well!
  8. At first I had some problems recording with it but I downloaded the newest version of vlc player, followed your instructions and it worked. So for those of you who can't get this working maybe downloading the most recent version would help.
    Hello
    I tried to use VLC to save stream videos (WMV's) and, after several different attempts, all I can save were just the audio, no video. Can anyone please provide some pointers? Thanks
  10. Member KneeGrow's Avatar
    Thanks-
    thanks you too, it worked on vlc 114 ass well
    i was about to pm baldrick when i had the idea to llook further ....
    River Tam: ''Can't look, can't look!'' My old avatar: dress, movies
    Version = VLC media player 1.1.10
    I've successfully been recording clips of the stream from mms://wms.carnyxlive.co.uk/abernethy/.avi (an osprey nest in Scotland) for several weeks - however, over the past couple of days the start of recording has been delayed for several seconds after the Record button is hit.
    I haven't changed any settings and an e-pal is having exactly the same experience, we can't think why this is happening. Do you think that VLC is not recording from the stream I am seeing it display on my screen, but from a delayed stream in the background? That's nutz isn't it?
    Maybe someone would be kind enough to test it out and see if they get the same result?
    clemenzina
  12. Has anyone come up with an answer to the question about recording only part of the stream?
    I have a stream that is over 7 hours long, and I want to save just 5 minutes at the end of the stream. I've successfully downloaded the section with VLC, by simply moving to that part of the stream when I start recording. But when I try to convert it to .mp4 the audio and video are out of synch.
    Any creative approaches to this problem?
    Thanx.
  13. Member Schmendrick's Avatar
    Most of the video live streams have a delay between the video and the audio track. When playing the stream live the player programme usually considers this delay to enable a synchronized performance. On the other hand apparently the programme you have used to convert the recorded stream was assuming the video and audio stream to be synced. If you use the programme MediaInfo you can obtain the delay of the audio track. If you use this delay with a video editing programme like Virtualdub (with AviSynth) then you may cut the piece of the clip you like and also apply the correct audio delay you should have found using MediaInfo to convert this piece of clip into the format you want with synced tracks.
    Schmendrick
  14. Thanks Baldrick for the very informative guide to save the streaming asf.
    Although my VLC version doesn't look like the screenshots, I managed to get them to save in my computer and play with WMP. Unfortunately, I'm unable to burn the files to CD.
    These are the steps I've done :-
    Under Convert/Save, I copy the mms: ...asf link, save it as .mp4 However, when I try to burn a CD it displays that the file is not supported. My files are all audio files (songs) and no videos at all.
    I also downloaded SUPER to try to convert to other formats but I'm not sure how to or what to choose as output.
    Would appreciate all the help I could get from you.
    Thanks.
    I want to watch pro cycling at http://www.procyclinglive.com/livestream/ will the vlc work?
    Schmendrick @ #43 - Thank you for that info
  17. Can someone please help me out related this LInk below
    I want to download video from this website and I want to play in Vunow box also call as JadooTv
    http://watchindian.tv/index.php?opti...per&Itemid=184
  18. Member
    I'm getting "Firefox can't establish a connection to the server at watchindian.tv"
  19. Originally Posted by clemenzina View Post
    Hello, Thank You for getting back with me. I'm using also Firefox I click on link I posted and I can play live Video. Try this link below try to click on it. Thanks
    It's my security software blocking it. Can't figure out how to unblock, sorry
  1. Replies: 7
    Last Post: 22nd Mar 2012, 15:33
  2. How to capture/record streaming Google, youtube,Flash, ASF,WMV,RM,Quicktime
    By Baldrick in forum Newbie / General discussions
    Last Post: 21st Feb 2012, 22:41
  3. vlc media player record problems
    By deanst2 in forum Newbie / General discussions
    Last Post: 5th Jun 2011, 08:58
  4. Cannot play ASF (WMV) files in Windows Media Player
    By javaluvva in forum Software Playing
    Last Post: 15th Jul 2010, 21:57
  5. Replies: 4
    Last Post: 21st Oct 2009, 23:55
