VideoHelp.com Forum
Results 1 to 30 of 50
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    Tools
    VLC Media Player
    Guide
    If you have a mms-link just copy it or open the video link your webbrowser and right click in the windows media window and select Properties and copy the location URL.
    Start VLC
    Select File->Open Network Stream
    Select HTTP/HTTPS/FTP/MMS and paste the URL/Link
    Select Stream/Save under Advanced Options and click on Settings
    Select Outputs and Play locally and File
    Select ASF as Encapsulationd Method
    OK and VLC should start play and also capture the video to the file.
    You can now play the ASF file with WMP or convert it to other formats using for example SUPER, VirtualdubMPEG2 or Windows Movie Maker.
  2. Member Soopafresh's Avatar
    Nice one, Baldrick
  3. Member Alex_ander's Avatar
    In most cases you can download the actual streamed RM or ASF file using NetTransport by loading either the initial link file or direct link gotten from it, with multiple connections to the host and resuming paused downloads. If the webcast is live, you can also record it to file (real-time in this case).
    P.S. Sorry, slightly out of topic.
    No, Net Transport...clickable link.......or WM Recorder or the free SDP Multimedia....but I still like VLC anyway.
  5. Member rakf1's Avatar
    Is there a way to start stream capture when needed only? What I mean is, say I'm watching a streaming video using WMP and then I want to capture only section of the stream while watching and stop capture whenever I want.... looks like this method will capture the whole stream and then I have to edit.....
    Thanks for this nice tutorial. I used the netTransport to record .asf file and changed the created file to .asf and now i do not know how to split it ? could any one tell me how to split that .asf file.thanks
    Thanks a ton
    For me method works with Firefox 2.0.0.1, not with my IE 6
    Try Cut Assistant
    Does VLC support NTLM I think it is? There are sometimes where when I use SDP it stops and It think its because of that. I don't remember the right acronym but its listed as non supported by SDP.
    Hi:
    Does anyone have this same instructions for the newest VLC 0.8.6a for Mac OS X 10.4.8?
    ... and can you save a streaming .rn?
  11. I followed your instructions to capture this clip:
    http://87.248.216.222/a304/o2-orange...v?MSWMExt=.asf
    When I tried to open the ASF file in Windows Media Player it says:
    Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
    Any suggestions?
  12. Member Schmendrick's Avatar
    The clip uses Windows Media Video 9 and Windows Media Audio 9.1 as codecs. I am using Windows Media Player 11 and do not have any problems to play the file insert its URL into "Open URL". I also have successfully downloaded the wmv-file replacing "http" by mms" in the files URL using SDP Multimedia as suggested by Baldrick as an alternative to VLC as I somehow was not able to download the file using vlc.
    Schmendrick
  13. Originally Posted by Schmendrick
    Schmendrick
    How would I use SDP to capture this URL:
    http://www.hbo.com/av/sopranos/seaso..._tea_wm_hi.wvx
  14. Member Schmendrick's Avatar
    @foochuck
    If you right-click on this URL and choose "Save Target As..." you save this "wsx"-file
    which actually is an "asx-file version 3.0". If you open this locally saved file using
    Wordpad you will find the following URL for the wmv-video-file itself which then
    you can download.
    http://wms.stream.aol.com/turner/gl/...tea_wm_384.wmv
    Have fun
    Schmendrick
  15. Schmendrick,
    I'm trying to download this file:
    http://wms.stream.aol.com/turner/gl/...ler_wm_384.wmv using SDP.
    It get's to 99% and then it stops. Do you have any suggestions?
    Hi
    I tried this method which the gent at the top suggested but i'm only geting audio after i've finished recording the stream
    Anyone help would be much greatly apreicated
    Originally Posted by Jeezy42
    Hi
    Anyone help would be much greatly apreicated :wink:
    Some times the same thing happens tome!!!
    please
    can anyone help me??
    THanks
  18. Member
    Thanks Baldrick for the great guidance, including the highlighted screen captures.
    - What does "Dump Raw Input" next to "file" do?
    - In the "Encapsulation Method" (e.g. file-type), what would be the best to save in? What are the advantages/disadvantages? There's many to choose from - MPEG TS, MPEG PS, MPEG 1, Ogg, ASF, MP4, MOV, WAV, Raw. I assume that WAV would be sound only w/o video.
    - What about Transcoding Options here? It would be cool if subtitles could also be recorded.
    - I'm unfamiliar with these other video conversion software -- SUPER, VirtualdubMPEG2 & Windows Movie Maker. Which do you recommend? Are any Freeware? What about video dubbing software? I'm currently recording with VideoLAN VLC and would like to cut out the first 5 minutes or so. It's too bad that VideoLAN VLC can't do it itself -- it seems to be the best video playing software out there and can do so many other things well.
    BTW, where'd you get that great Avatar? I know a guy who makes a face like that, looks almost exactly like him, glasses and all!
    I'm trying to use this method to download/save this file & getting errors
    http://stanford-online.stanford.edu/...-ee380-300.asx
    Error: Unable to open 'ASF http://lang.stanford.edu/courses/ee380/080604/080604-ee380-300.wmv'
    It's listed in WMP's properties as:
    *Windows Media Audio 9.1
    20 kbps, 22 kHz, mono (A/V) 1-pass CBR
    *Windows Media Video 9
    *Under "Media Usage Rights" in the WMP properties it says "This file is not protected."
    I saved it & opened it with notepad and tried http://lang.stanford.edu/courses/ee3...-ee380-300.wmv
    via notepad:
    Error: Unable to open 'mms://lang.stanford.edu/courses/ee380/080604/080604-ee380-300.wmv?MSWMExt=.asf'
    then i saved the http://lang.stanford.edu/courses/ee3...-ee380-300.wmv & looked at it in notepad:
    so i tried http://lang.stanford.edu/courses/ee3...v?MSWMExt=.asf
    [Reference]
    Ref1=http://lang.stanford.edu/courses/ee380/080604/080604-ee380-300.wmv?MSWMExt=.asf
    Ref2=http://192.168.10.101:80/courses/ee380/080604/080604-ee380-300.wmv?MSWMExt=.asf
    & got Error: Unable to open 'mms://lang.stanford.edu/courses/ee380/080604/080604-ee380-300.wmv?MSWMExt=.asf'
    none of them seem to work.
    Does anybody know the proper method to save this file?
    I also encounter this problem. However, I found a method to get the asf file correctly.
    Method : you can use copy and paste function on the asf file during encoding the streaming video for the last five seconds. You will get the playable asf file as a copy of the orginal file.
    Is there an updated version of this guide for the new menus in VLC 0.9.4?
  22. Mod Neophyte Super Moderator redwudz's Avatar
    Blackadder, an English TV sitcom : http://en.wikipedia.org/wiki/Blackadder
  23. Member
    I've installed the latest VLC version 0.9.9 and I've been trying to rip mms live stream with it and have stumbled into this thread that deals with an older version of VLC, but doesn't inform which one - I'm guessing it's the 0.8.5, from Dec/06?
    I don't mind installing an older version of this app, as long as it captures/indexes/plays mms live stream and does it well. It's been impossible and complicated with the latest version, and the dialog windows are different from the ones posted here. Please help.
    Thx - Denise
  24. Member
    Have tried VLC and various other software, with no luck.
    Anyone who knows how to download this stream?
    http://secure-wm.qbrick.com/90807/kl...f931528d520188
  25. Member
    Originally Posted by Soopafresh
    Nice one, Baldrick
    Thank you sir for UR help! It works for me... but just one problem... where is the sound???
    //JC
    JC
  26. Here is the up-to-date screenshot instructions on how to save video streams (or mms:// videos) to a file using VLC Media Player.
    This uses VLC 1.0.0 but should work the same in the new 1.0.1.
  27. Member
    I want to download video from this website
    http://hayley-westenra-international...e-keyhole.html
    Can anyone help me? Because I can't downlaod with realplayer
  28. Member
    I want to save this stream :
    http://live.billboard.com/Concert/View/200228
    only I can't even get it to stream in VLC media Player.
    Any ideas ?
  29. Member
    That might be rmtp-e files and they can't be downloaded. You should simply use a screen capturing software, it captures the videos streaming right over. Well, the one I'm using for some time is Tunebite, this new version can capture those kind of formats and also converts the videos to any formats you need.
  30. Member
    Hi there,
    I'm trying to capture a live sreaming video using vlc but no luck :
    windows media player shows that link is :
    http://www.omroep.nl/live/thema/nos_politiek24-bb.asx
    Please help
  1. Replies: 7
    Last Post: 22nd Mar 2012, 15:33
  2. How to capture/record streaming Google, youtube,Flash, ASF,WMV,RM,Quicktime
    By Baldrick in forum Newbie / General discussions
    Last Post: 21st Feb 2012, 22:41
  3. vlc media player record problems
    By deanst2 in forum Newbie / General discussions
    Last Post: 5th Jun 2011, 08:58
  4. Cannot play ASF (WMV) files in Windows Media Player
    By javaluvva in forum Software Playing
    Last Post: 15th Jul 2010, 21:57
  5. Replies: 4
    Last Post: 21st Oct 2009, 23:55
