VideoHelp.com Forum
    Hello all: I just made a VCD and it plays back in VCD-player successfully. BUT I found a new question: the sound is a little bit lag behind the image, they are not in synchronization!
    I checked the original file for making the VCD, it does synchronize while playing in the PC.
    Why the Nero-Express makes this mistake during the manufacture of VCD? --Zhao
  2. Member Krispy Kritter's Avatar
    Basically because Nero sucks.
    For best results, you should manually convert the files. Or find a different "one button" tool for your conversions.
    Google is your Friend
    It depends on what you played it in on the pc ... not all programs perform the same ... so it's best to test the file in more than one player , too make sure the problem dosent actual exist within the file , before biting nero .
  1. VLC Player: no image, only sound
    By gracie283 in forum Software Playing
    Last Post: 10th May 2012, 10:01
  2. DVD synchronization, without synchronization device and normal dvd players
    By 10shyam in forum Newbie / General discussions
    Last Post: 9th Mar 2011, 17:52
  3. Replies: 4
    Last Post: 10th Aug 2010, 10:16
  4. subtitles synchronization
    By Grendel007 in forum Subtitle
    Last Post: 29th May 2010, 22:22
  5. Have image but no sound
    By ralphy in forum Audio
    Last Post: 13th Sep 2007, 23:53
