hi
i have some subtitles in sup format . you know how can show this subtitles like srt , sub ant etc ... with avi or another formats ?
Thread: how can show sup subtitles ?
by:
tirdad
admin of farsisubtitle.com
Hi-
You can't show SUP subtitles in an AVI the way you can other formats. You can convert them to IDX/SUB format. They can be used with AVI. You can also go back to the original DVD and extract the IDX/SUB files. Or you can OCR (convert to text based subtitles, such as SRT or SSA) either from the IDX/SUB files, or from the IFO of the DVD.
SUP subtitles can be muxed into DVD using authoring apps (Muxman, IFOEdit, Rejig) that accept subtitles in that format.
i know . you know persian language is diffrent with english . in english 26 capital letter , 10 number & some characters . but in persian 2 letter make another word , it's so difficult convert it to sub with OCR . thanks for your answer
by:
tirdad
But I said they can easily converted to IDX/SUB format (or IDX/SUB can be extracted from the IFOs/VOBs using VobSub Configure). IDX/SUB are BMP or picture or image based subs, just like SUP. IDX/SUB can be played with AVI. No problem for the Farsi subtitles. You only have to have DirectVobSub installed, and the IDX/SUB subtitles will play very nicely with the AVI.
Bamana khoda
thanks friend , it's prefect .
by:
tirdad
greek subtitles do not show at all!!
By eleeeni in forum ffmpegX general discussionReplies: 6Last Post: 27th Jul 2011, 14:09 -
the greek subtitles do not show at all
By eleeeni in forum Video ConversionReplies: 2Last Post: 26th Jun 2011, 13:52 -
subtitles won't show!
By wawawa in forum SubtitleReplies: 1Last Post: 9th Nov 2009, 03:16 -
Subtitles won't show in TMPGenc
By knn03 in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2009, 21:12 -
can't get srt subtitles to show up
By fmiller4 in forum ffmpegX general discussionReplies: 5Last Post: 19th Jan 2009, 12:16
