VideoHelp.com Forum
    Hi everyone I have a bit of an odd problem, I do not get thumbnails for AVI or any 'movie' format.
    I know that Win XP does this because I can see it on other PCs.
    This sounds like it is just a presentation problem but I believe it is also related to some more functional problems:
    Windows Movie Maker doesn't work, I get a 'class not registered' error whenever I try to import any type of video file (I can edit using Nero Vision but no thumbnails there either).
    When I burn a DVD using Nero there are no thumbnails available for the title/chapter menus.
    Windows media player 11 doesn't display the location/time after about the 60 minute mark (media player 10 did so I'm not sure about this one).
    Any ideas would be greatly appreciated.
    Thanks,
    Volpo
  2. Member Krispy Kritter's Avatar
    I believe there is a menu option to enable thumbnails, I don't recall exactly at the moment. I have it disabled because it uses resources and slows opening times of folders as it has to scan/create/open all of the thumbnails.
    After it is enabled, windows should display thumbnails for all video formats supported by WMP.
    Google is your Friend
  1. Replies: 1
    Last Post: 4th Nov 2011, 15:20
  2. Video thumbnails are upside down
    By thegeeman in forum Newbie / General discussions
    Last Post: 30th Mar 2011, 05:36
  3. Video Thumbnails
    By mr. goodbytes in forum Software Playing
    Last Post: 11th Aug 2010, 23:11
  4. Playing Video on display 2 and display 1 goes black
    By sidewaysdriver in forum Software Playing
    Last Post: 3rd Aug 2010, 00:36
  5. TDA won't display video thumbnails after Vobedit
    By spiritgumm in forum Authoring (DVD)
    Last Post: 25th Aug 2007, 14:35
