  1. Is there different AAC types?
    that need different codecs?
    Or is it only one?
    What is SBR+PS and so on?
  2. Member rakf1's Avatar
    Sep 2006
    There are many types of AAC - AAC-LC, HE-AAC, HE-AACv2....
    AAC-LC with SBR = HE-AAC
    AAC-LC with SBR and PS = HE-AACv2
    (SBR - spectral band replication, PS - Parametric stereo) better coding efficiency...
    Nero codec should handle all types...
  3. Ok!
    I got a dvd player that some people think should play AAC,
    but when i try it says that it don't got the right codec!
  4. Member rakf1's Avatar
    Sep 2006
    Use Mediainfo to find out which type of AAC you have..., I'm guessing it only supports AAC-LC. Try creating a AAC (.m4a) file in itunes and try playing it..
  5. Its a AAC-LC SBR
    Is there any good prog. that can convert AAC to AC3?
    The player support AC3..
    Now i'm converting the AAC's to Mp3, and it takes a very long time. DbpowerAMP and lameXP does not work.. so now i'm converting to *.wav with flaad and then i use Audacity to convert to *.mp3..
  6. Member rakf1's Avatar
    Sep 2006
    You can use Mediacoder or Belight to convert AAC to AC3
  7. Thanx! Mediacoder helped me alot!
    Fast and it works perfect on my computer.
    Belight only support AAC output, not input
