Ok, I'm rather new to this area, so please bear with me.
What I'm trying to do is find a cable setup that will allow me to connect my PC's DVI output to both my HDMI input on my TV as well as the VGA input on my LCD PC monitor. I currently have a DVI to HDMI cable for the TV hookup, and I have a DVI->VGA adapter for the monitor. My problem is I only have one DVI output on the video card.
So, is there a splitter cable or something that will get the job done for me?
Thanks...
Can't get there that way. Does the display card have a second output (DVI-I or VGA)?
http://www.kiva.org/about
No. The only other output on the video card is S-Video. 1 DVI and 1 S-Video.
You can this way
DVI-I to this. It splits DVI-I to VGA and DVI-D
http://www.ramelectronics.net/html/DVI-hdmi_adapt.html
Then DVI-D to HDMI and VGA to VGA
Fantastic! That's kind of the idea I was thinking, but without the extra cable connections. This should work just fine.
One other thing...if I can ask a newbie question.
What's the difference between DVI-I and DVI-D? Should I expect any compatibility issues between the two when hooking up these cables?
DVI-I (as found on display cards) carries pins for DVI-D and DVI-A (same as VGA). That is why VGA adapters can be used and with most cards, two monitors can be run from one DVI-I connector (i.e DVI-D and VGA).
DVI-D will connect to HDMI for video only. You will nee to run audio separately.
http://en.wikipedia.org/wiki/DVI
http://en.wikipedia.org/wiki/HDMI
http://forum.ecoustics.com/bbs/messa...79/122868.html
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Need help from video experts, hdmi to vga to dvi
By edgarmiranda in forum Newbie / General discussionsReplies: 3Last Post: 20th Jun 2011, 22:24 -
HD 720 sanyo: A way to downstep from hdmi, vga or dvi?
By reallyreallyconfused in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2010, 22:50 -
Connect VGA/DVI/HDMI source to Component HDTV
By jstewar9 in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jan 2010, 15:11 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 20:37
