VideoHelp.com Forum
    How do I download the mpeg2enc binary? I can get to the page and copy it but I don't know how to download it.
    I don't understand what CTRL-click and ten " Download link on disk " means.
    Can someone help?
    Thanks so much.
    Well if you provided the page link , youd know how ???
    I'll assume they want you to hold down the ctrl key ... then click the link in order for it to download correctly .
    It's a rare option that very few site's use ... but one site I visit all the time refer's it to a way of controling some download managers ... getright , and other's ... I think it bypass's them as they can cause issue's with multiple part download's ... which the site I visit inform's you " you have been banned for 7 hour's ... dont do this again" .
    Doing it again bans you for 21 hours .
    Doing it again bans you for 21 day's .
    Doing it another 2 time's might just ban you for life ... lol ... wonder if I do it again if I get banned for eternity ... lmgo
    If you have a download manager installed that use's multiple part downloading ... set it in the settings to 1 only , then save , and get the program to exit ... it should stay put that way until you otherwise change the setting .
    I see the sucker now ...
    Hold ctrl , and click the link ... download will begin asap ... that's the thing .
    If you just click it , you might end up having the source code displayed in the browser .
  3. Member GTRBudda's Avatar
    If I'm not mistaken, that's part of DVDAuthor. It is included in DVDAuthorGui, Gui for DVDAuthor, DVDStyler...... quite a few others.
    Well not knowing where this page is , dose not indicate the actual os involved required ... only by name .
    I found this "how I do it" on an apple tool website .
    Maybe they wanted the one for mac ... or linux ... instead of the one released for windows ...
  5. Member GTRBudda's Avatar
    Good point, I should have looked before I lept. Duh, sorry about that. If it helps, I think I found it here:
    http://homepage.mac.com/major4/download.html
  1. mpeg2enc binary not working
    By yabastamedia in forum ffmpegX general discussion
    Last Post: 19th Jan 2011, 12:02
  2. Problem opening mpeg2enc binary
    By itegil in forum ffmpegX general discussion
    Last Post: 6th Aug 2010, 22:48
  3. Can't install mpeg2enc binary
    By cpwhaley in forum ffmpegX general discussion
    Last Post: 23rd Jul 2008, 13:50
  4. Problem with mpeg2enc binary
    By lkearl in forum ffmpegX general discussion
    Last Post: 11th Aug 2007, 03:47
  5. mpeg2enc binary link does not Work
    By loveformetal1 in forum ffmpegX general discussion
    Last Post: 6th May 2007, 06:40
