Hi, I have a standalone DVD player which can play XVID/ AVI files successfully.
I recently tried to put a SRT subtitle file in the same folder as the avi file. I also made sure the video and srt file has the same name. Then I burn it to CD.
However, the subtitle is not displayed.
How should I correct this?
Thank you.
Thread: Load Subtitle from avi CD
Did you press the subtitle button on the remote control?
He's a liar and a murderer, and I say that with all due respect.
What player?
When I press the subtitle button, it shows "Subtitle [OFF]" in a faded color, which I'd assume is non-available feature.
When I press again, nothing happens as well.
My DVD player is of an obscure brand, but I'm confident of its quality though.
The subtitles of DVDs work just fine on it.
I'm thinking of trying to change the .SRT extension to .SUB extension. Will it make a difference?
Btw, the method I first use above, that is the standard way of burning subtitle with avi files, rite?
Does your player support AVI subtitles at all? Your method seems sound. Changing file extension is rarely a solution to any problem.
/Mats
I have the same problem with my DVD player. The AVI and the subtitle file(srt) has the same name and it isn't displayed.
My DVD Player: Sony DVP-NS63P
someone can help with this player?
Thanks!
As I was thinking, I've used spacing in the filenames of the AVI and SRT files.. like "Surface 7.avi" and "Surface 7.srt".
Maybe it's a spacing issue? cos the player only shows Surface_.avi on the menu.
Spaces in file name s is always a bad idea. But do you know your player support subtitles at all? I browsed the specs for the Sony DVP-NS63P and couldn't see subtitles mentioned.
/Mats
With autogk no subtitle load window after clicking ctrl-f8
By 3l8x in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2010, 16:19 -
Subtitle Workshop 2.51 can't load a video
By Charmer in forum Video ConversionReplies: 9Last Post: 17th Apr 2010, 10:42 -
How can I load a subtitle in PowerDVD
By dsajkw in forum SubtitleReplies: 0Last Post: 16th Oct 2009, 06:55 -
avisub blocks when I load .avi file
By ebergi in forum SubtitleReplies: 2Last Post: 23rd Jun 2008, 16:50 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 18:26
