Hi everyone, I'm familiar with all the tools to do this but not so familiar with the Avisynth scripting. Any advice or help with my script is appreciated.
I have a AVI that is 1.3 GB (over 3 hours of footage). Clearly this won't fit onto one NTSC DVD but I know the frames that I want to trim to break this up into two DVDs. Here is the data from Gspot:
codec; divx 5.02
resolution: 544x416
fps: 23.976
DAR: 1.3
PAR: 1
My question is...I want this to fit onto NTSC DVD and I believe the aspect ratio is close to 4:3 already. I have a widescreen TV so I don't want to stretch the AVI all the way to 720x480 (although I know I need this for DVD compliance). Stretching it more, in my mind would take away from the image quality.
My question is this...how can I tell my script that I want a DVD compliant file size, but add the proper borders so that I'm keeping my original resolution in-tact but simply putting borders to fill the rest of the screen...all the while trimming the AVI file up to a particular frame? Ive seen bicubic resizing and the lanczos but I'm not sure in which scenario to use either or really how. Also do I need a separate editing application or does avisynth trim files natively?
From there I can then figure out the length and do the rest in the other apps. I'm just a little bit 'scripting' challenged. Plus the avisynth sites are down right now so that limits my brushing up on the commands and what they mean.
Thanks in advance.
Thread: Resizing AVI to fit DVD
Hi-
With the ITU box checked, I get:
LanczosResize(704,480)
AddBorders(8,0,8,0)
I use FitCD to find the crop/resize/addborders and to get a basic script, and so should you. Then encode for 4:3.
FitCD. And you don't keep the original resolution intact. Your AVI is 1:1 but your DVD will be 4:3. You have to adjust the resolution. Until you understand what's going on (and maybe even long after) use FitCD for the job. Here's Fulcilives' guide to FitCD:
http://forum.videohelp.com/viewtopic...487285#1487285
Use the Trim Command (or cut the AVI in VDubMod before doing the encoding):
http://www.avisynth.org.ru/docs/engl...lters/trim.htm
There's a pretty good mirror here:
http://www.avisynth.org.ru/docs/english/
If you want letterboxing of 4:3 image inside 16:9 screen, here are the numbers for NTSC.
Resize your 4:3 source to 544x480, add (88+88) vertical borders and encode as 16:9.
P.S. slightly corrected
do i need to use 3:2 pulldown on HCEnc?
If you're encoding for 23.976fps, then you'll need to apply pulldown some time, either during the encoding, or afterwards, maybe using DGPulldown.
The pulldown in HCEnc is currently flawed. If you encode with HCEnc then DGPulldown is the preferred method of applying pulldown to your file.
Here is a thread that sorta became my mini-guide for encoding XviD/DivX MPEG-4 files to DVD using a variety of freeware software: CLICK HERE
Avi resizing or creating quick dvd using avidemux
By striker9 in forum Video ConversionReplies: 13Last Post: 2nd Nov 2010, 11:01 -
DVD to AVI resizing problem
By okman in forum DVD RippingReplies: 10Last Post: 2nd Jan 2010, 00:46 -
Resizing to Fit TV Screen
By bolson1 in forum EditingReplies: 2Last Post: 12th Feb 2008, 21:49 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 10:18 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 21:08
