Has anyone had the problem of channel memory/set-up loss with the Toshiba D-R5 when it is turned off? During the first month I had it, no problems. Now, everytime I turn the thing off, it loses the entire channel memory and basically any other set-up I have performed. This requires me to go back through the channel scan. I'm just leaving it on 24/7 now but would like to get this resolved.
I have emailed Toshiba and not heard a response yet. Any help would be appreciated.
Thread: Toshiba D-R5 Channel Memory Loss
I have had mine for about two months now. About a week ago I noticed it changed from the broadcast setting to cable. Eventually it started losing the whole channel list. It does seem to only happen when you turn the power off. I tried unplugging it for a day in case it was some kind of software bug, no luck.
Have you had any luck getting the problem corrected? I looked around Toshiba's web site and haven't come up with anything. Did they ever reply to you?
If your still watching this post I'll let you know what happens with mine.Randy
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 04:35 -
Toshiba SD6100 ...Position Memory?
By Tom81 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Oct 2008, 13:30 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19
Statistics
Newest guides
Latest tool updates
New media comments
