VideoHelp.com Forum
    I am using AC3 Filter when I play avi/dvix files in MCE or WMP. The problem is that I am not getting the digital pass thru to trigger my A/V receiver to indicate it's processing DD sound. When I watch live HDTV that broadcast DD sound, it's also not being detected. I was using AC3Filter v1.01a rc5 without any problems but since I have bought a seperate sound card, it won't pick up DD sound. I've tried the newest AC3Filter v1.11 with the same results. I've got the SPDIF box checked, PMC 24bit, and 5.1 channel output.
    I've tested this on my main rig which is using SPDIF to Logitech system that decodes DD sound. I get the same results with any version newer than v1.01a rc5. Seems very odd to me to see any version from 1.03-1.11 doesn't work for me. Any tips?
    You can also try ffdshow, in the audio configuration under codecs set ac3 and dts decoding to spdif.
  1. AC3 Filter
    By BobbyScot in forum Software Playing
    Last Post: 28th Aug 2009, 09:54
  2. AC3 no longer works w/ WMP 11
    By dmjerbear in forum Audio
    Last Post: 5th May 2009, 22:14
  3. [VLC] AC3 video file + spdif output = stereo?
    By SANAFABICH in forum Software Playing
    Last Post: 10th Aug 2008, 16:59
  4. Replies: 8
    Last Post: 7th Mar 2008, 14:45
  5. Question about AC3 Filter...
    By GangstaRap in forum Audio
    Last Post: 25th Sep 2007, 11:21
