VideoHelp.com Forum
Closed Thread
Results 1 to 10 of 10
    i have a 700mb movie file(.avi) and i want to make a vcd only on one disc.i've tried nero 6 and 7 but the output file comes up to 730mb which doesnt fit on the 700mb cd.
    i have a dvd burner too but i want to make a vcd.Please help me.i've read other topics but i'm not able to find the solution.
    the duration of the movie is 82 mins.
  2. Member Alex_ander's Avatar
    VCD's file system (unlike data CD) allows MPEG file size to be up to ~800MB on a standard CDR so if you have a VCD image file of the size you tell you'll be able to burn it.
  3. Mod Neophyte Super Moderator redwudz's Avatar
    VCDEasy may be a better choice for making up VCDs. I haven't used that format for a while, but when I used SVCDs, you could burn them in Mode 2 from a disc image and get about 830MB on a 700MB, 80 minute CD. Not sure if the VCD format can use that.
    ok so u guys r saying that i should convert the avi file to mpeg first and then burn?
    thanks for ur answers guys
  6. Mod Neophyte Super Moderator redwudz's Avatar
    It would have to be a MPEG-1 if it's a VCD. If you just wanted a AVI CD data disc, you would use a lower bitrate for a smaller file, but only a computer or a Divx type player would play it.
    A VCD uses a fixed bitrate of 1150Kbps, so the size is dependant on the running time of the video. If you wanted it smaller, you would need to shorten it, or use a out of specification bitrate, which could cause playing problems. See 'WHAT IS' VCD to the upper left for the VCD format. <<<<<<
    ok so what software do i use to shorten it?
    82 minutes of movie is too long for even an 80 minute CD-R for VCD. You have several choices.
    1) Do NOT use Nero for encoding! Use TMPGenc (there are guides here at this web site on how to use it) and use a bit rate of about 1050 Kbps instead of 1150 and it will be small enough to fit.
    2) You can try to use Nero to overburn the 82 minutes onto an 80 minute CD-R, but probably it will fail.
    3) I don't know if you can get these in India, but if you can find 90 minute CD-R discs, you can probably burn to those. Most burners can burn to the 90 minute CD-Rs, but you must burn as slow as possible for it to be successful. The 90 minute CD-Rs violate CD-R standards (80 minutes is the maximum length for a CD-R according to the standards), but most devices can play them anyway. By the way, Nero will recognize all 90 minute CD-Rs as being only 80 minutes, so you set Nero to overburn up to 90 minutes before burning these discs.
  9. Mod Neophyte Super Moderator redwudz's Avatar
    You could try this with your VCD file: Use vcdgear to create an image file of your oversize VCD file. It will probably be a BIN/CUE file. In Nero Burning ROM go to 'Recorder>Burn Image' and select the CUE file.
    This should get your 82 minute file onto a VCD format disc and be playable on most any VCD type player. I haven't done this with a VCD file, but it's worth a try. This will use Mode 2 burning. Mode 2 eliminates the error checking files from a CD. You don't need them with a video anyway, and it frees up more than enough space on a 700MB CD to fit up to a 830MB file in there. This is not the same as overburning.
    do any of you know where i can get a crackd version of vcdeasy or vcdgear?thanks
    You are in breach of the forum rules and are being issued with a formal warning.
    Read the rules / AUP again: http://forum.videohelp.com/viewtopic.php?t=124514
    This is not the place for warez, cracks & c. Use what's free, buy what's not.
    / Moderator mats.hogberg
  1. Making a VCD to send to the Philippines
    By StrikerZERO in forum Authoring (VCD/SVCD)
    Last Post: 7th Dec 2010, 09:11
  2. have a problem making multi-episode dvds??
    By roboroach in forum Subtitle
    Last Post: 18th Dec 2008, 16:39
  3. Problem making contact sheets from vids
    By majax79 in forum Newbie / General discussions
    Last Post: 13th Jun 2008, 17:26
  4. Making VCD Copy
    By audiophile in forum Authoring (VCD/SVCD)
    Last Post: 18th Sep 2007, 07:20
  5. General Guidance and Hardware req. for making VCD with Digital Camera
    By dpilot83 in forum Newbie / General discussions
    Last Post: 11th Jun 2007, 05:53
