THANKS TO WAHEED FOR THIS POLL IDEA:
http://forum.videohelp.com/viewtopic...281798#1281798
How many speakers do you have on your PC?
Headphones only
Standard 2 Speakers
2.1
4.1
5.1
6.1
7.1
more than 7.
None - no speakers attached - except for the computer speaker - the beep type.
I have a LOGITECH 5.1 speaker system but it's not currently hooked up. I am using a 2.1 system currently. I used the 5.1 for another project but never got around to rehooking it to my desktop.
Results 1 to 30 of 32
The majority of the time just the stereo speakers. The sound card has coax out so sometimes I hook it up to the home theater and listen to music on the 5.1.
His name was MackemX
5.1 via S/PDIF to receiver-amp
2 speakers in LCD monitor
2 TV speakers monitoring IEEE-1394 output through ADVC-100 (DV to analog transcode)
I guess that totals to 10 speakers.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I guess you should pick the configuration you use most often for the poll choiceOriginally Posted by edDV
2x 1" speakers on the LCD monitor connected analog to the sound card.Originally Posted by yoda313
I've got an old set of Cambridge Soundworks 4.1 speakers plugged in to my Audigy 4 soundcard as I think I can more accurately judge where sounds are coming from in games than I could with a set of 5.1 speakers. (Which are now plugged into the PVR in the bedroom!)
Main Pc:
Creative Sound Blaster Audigy 4 soundcard
THX-Dolby-DTS (play's DVD AUDIO Also)
5.1, (62 Watts RMS per channel X4 for satellites; 69 Watts RMS for center channel)
12" subwoofer (188 Watts RMS)
With remote (still in package)
One pc has 2.1 (little satt's w/sub) cambrige soundworks
One pc has some cheap little speakers for ??
One has 4.1 (4 little satts & sub) cambrige soundworks
All with various creative soundcards.Originally a member since 2001, LONG LIVE TARAN's!!!
2.1 Creative
I might get this, though:
http://www.alesis.com/product.php?id=25
Alesis ProActive 5.1 • 500 Watts • Dolby® Digital & DTS® Hardware Decoding • THX® Certified
Junk all Junk..sorry but I like TUBE AMPS too (don't have one tho' I have:)
I have Three 2.0 Stereo Systems hooked up in one LIVING ROOM
1. ALTEC VOICE of the THEATRE 15" woofers plus Metal MultiCell Horn
2. JANzen HYBRID 10" woofers with ELECTROSTATIC PANEL HIGH END
3. Design Acoustics DA-8 Cubes (8" Cube Mini Speakers)
Driven by H&H electronic, Quad Acoustics, or Crown AMPLIFIERS
Yep, those are kik @$$..Originally Posted by Epicurus8a
I had that setup for about a year until i blew up my sub rock'n
Then i bought a new system with a bigger 12" subwoofer & satt's 8)
But i seriously rock when working until i can get to my home systems :P
They have the set just below that one at BB for pretty cheap.
http://www.bestbuy.com/site/olspage....=1091099783220Originally a member since 2001, LONG LIVE TARAN's!!!
Pic of my speakers
Do those require earthquake cross bracing on the wall joists?Originally Posted by dcsos
Great...another tube amp snob,tubes are sooo 20th century. :POriginally Posted by dcsos
As for my PC's:my HTPC is hooked up to my 5.1 amp via coaxial and my video PC has 2.1(8" sub).
These are similar to the top end of my Janszens-also has woofer
this company is back in 2006!
http://www.janszenloudspeaker.com/home.htm
Note: I never said I have a tube amp, Just like them for "softening " the sound of the computer!
I had a 5.1 set, but it gave out on me, so I use stereo speakers for now.
Believing yourself to be secure only takes one cracker to dispel your belief.
ENJOY!
as that's the actual brand on the front of the speaker!
I use a pair of somewhat cheesey Jensens for "casual use". For hardcore stuff, I use a 5.1 headset with a mic. It's not perfect 5.1, but decent enough. My real speakers live on the HiFi in the living room: a pair of dynaudio monitors with a matched pair of isobaric loaded passive subs.
Usually long gone and forgotten
I'm pretty ghetto fabulous. I had a pioneer SS amp, 2 jbl tower speakers (with 8" woofers), and a pioneer surround speaker package (c, sl, sr). I then went from the sub out to another stereo amp and used it to push 2 10" jensen car subs in a bandpass box! It was a rumbling good time till the jensens blew. Had them for about 10 years. now I'm looking for better 10"s to put in that box
I'm actually about to swap my jbl's to the rear surrounds and use some older sharp monster tower speakers as FL and FR. they have 2 12's in them which I'm sure my SS amp will push poorly. So I'll still need the subs to fill out the low end. It should sound much better with all full size speakers (except for the center), however.
Now that I have big sound I need big picture! A projector will be my next purchase.
Not including my Sennheiser 580's I have a Logitech Z-5500 500 Watts 5.1 Speaker system hooked up to a Terratec Aureon 7.1 Universe sound card.
since I play BF2 I use Plantronics headset
Logitech Z-640 5.1
http://www.tweaknews.net/reviews/logitechz640/
which computer???
2 are connected to stereo PC speakers
1 is connected to a 5.1 receiver with dual subs
1 is connected to a 4.0 receiver (that only has 2 speakers hooked up right now)"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
Logitech Z680 actually they look identical to the Alesis ProActive 5.1.
Like them so much I got another for the TV in my bedroom.
I have a 6.1 Sound Blaster Audigy 2 Platinum THX sound card connected to my 6.1 Megaworks 650D THX speakers:
2.1
and thanks to yoda for keeeping the polls alive!
Always glad to serve!!!!!!Originally Posted by Baldrick
I have two speakers and a subwoofer connected to my computer.
computer outputs to sound blaster live usb, hooked up to a kenwood amp, which powers a set of tannoy's, and a set of wharfdale diamond 3's which must be about 20 years old now but still sounds sweet
fixing shorted computer speakers
By gooberguy in forum ComputerReplies: 15Last Post: 18th Jul 2010, 21:22 -
Using PC Speakers on Computer and TV
By imdaman in forum AudioReplies: 3Last Post: 26th Jun 2010, 23:41 -
Using computer speakers for my tv.
By imdaman in forum AudioReplies: 12Last Post: 28th Nov 2009, 10:47 -
How do you play music on the computer using all 6 speakers?
By Obamargarine in forum ComputerReplies: 5Last Post: 10th Mar 2009, 16:40 -
Best computer speakers
By justalice in forum ComputerReplies: 13Last Post: 11th Apr 2008, 13:34
