VideoHelp.com Forum
  1. Hi everyone can you help with this problem after yeatrs of using mainconcept to convert my avi files to mpeg successfully i now have this problem when i converto i get teh video but no sound using winavi does not have this problem any ideas?
    cheers
  2. Member Krispy Kritter's Avatar
    Is your "mainconcept" up to date? Possibly you are converting files using newer codecs that it doesn't support.
    Google is your Friend
  3. Hi what is the latest version of mainconcept and thanks for the reply
  4. Member Krispy Kritter's Avatar
    I don't know, I don't use. I expect you would need to check their website.
  1. Frameserving From VirtualDub to MainConcept
    By hech54 in forum Video Conversion
    Last Post: 8th Mar 2012, 09:24
  2. Mainconcept Reference - 2ch audio
    By ranosb in forum Video Conversion
    Last Post: 11th May 2009, 06:10
  3. Replies: 15
    Last Post: 2nd Apr 2009, 15:03
  4. MainConcept products !? use it or not..
    By Harviz in forum Editing
    Last Post: 1st Dec 2007, 20:14
  5. Mainconcept encoding problem - Audio
    By Mysteriouskk in forum Video Conversion
    Last Post: 25th Nov 2007, 09:25
