VideoHelp.com Forum
Thread: 480p
    Should all dvd's that I burn off with my computer play in 480p when played in a p.s. dvd player hooked up to a hdtv? I use COnvertx2dvd and the sources for all of my video is dvd.
    The player does the upconverting in hardware, so the source should not be a factor.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. Member edDV's Avatar
    A progressive DVD player will output either progressive or interlace DVD discs at 480p @ 59.94 frames per second to a progressive TV.
    Progressive discs contain both fields of progressive frames stored at 23.976 fps. These fields get combined into frames and output in a 3:2 sequence as 59.94 fps.
    Interlace discs contain separate fields at 29.97 frames per second (59.94 fields per second). The DVD player needs to convert 480i to 480p. The methods used range from crude deinterlace blends to high quality "cinema" inverse telecine or advanced deinterlacing. This is what separates a $50 K-Mart special from a $150 quality player.
    An HDTV will accept 480p, upscaling 720x480 to the native resolution of the display.
    Some players will upscale internally and output as 720p, 1080p or 1080i
    Okay, thanks very much for the info!
  1. 480p to 720p
    By Ally68 in forum Newbie / General discussions
    Last Post: 9th Dec 2010, 17:09
  2. Help Resizing 720p » 480p
    By Enkidu in forum Newbie / General discussions
    Last Post: 27th Jul 2010, 13:17
  3. How can I check to see if a DVD is 480p or 480i?
    By Joe The Dude in forum DVD Ripping
    Last Post: 9th Feb 2008, 07:30
  4. 480p problem
    By ieh4f in forum DVD & Blu-ray Players
    Last Post: 4th Jan 2008, 00:05
  5. Best way to convert 720p footage to 480p?
    By Mysteriouskk in forum Video Conversion
    Last Post: 6th Dec 2007, 20:23
